2025 AWD and Powershare - First impressions
carsly
Vin
Princeton, NJ
LR Defender, CT AWD
This is a nice solution, but if your out of town, and your power goes out and you loose heat, and your pipes freeze and bust. It'll cost you way more than that. I know this is an unlikely situation, but it happens.
if you’re away that long in the dead of winter shut the main and drain the pipes ;-)
Gaximus
Mead, CO
Software Developer
I usually do that, but have forgotten, and we’ve had freak storms come in when out of town for just a few days. It’s a piece of mind setup. I can also start up my fireplace if need be, but that requires getting out of bed, and a lot of work, and a lot of time just to get warmth back in the house.
My PowerShare install was only $3700, plus I got all the hardware for free(or 120k with a free truck depending on how you look at it) so its a lot less of a justification to make than OP.
akenis
Andrew
FL, USA
23 MYLR and (Apr-Jun CT AWD)
Pilot
I looked into this option and at first it sounds great. The problem with powerwalll is one unit does not provide enough energy to do many useful things. For example to run my heat pump with resistance backup heating would require at least 4 powerwall's. At that point its not very cost effective as you already have a cybertruck with the equivalent of 5-6 powerwalls.
Correct. 1 PW only drives 11.5KW (48 A on 240 V) for 13.5 kWh.
That's infinitely more than a bloated 3V gateway without the truck connected.
With PW AND the Truck plugged in you get 2x the Power....48A x 2, or roughly 100A service. And the capacity of 10 PW.
For extended outage, unplug the truck and go full fillr up while the house stays powered by the PW.
(Actually not sure if the system would use truck or PW first. But I have a disconnect between PW and gateway, so I could conserve the PW and just use the truck until I needed to filler up at a supercharger).
AlmostHuman
Earth
Model X, Cybertruck
Human
Friendly suggestion: could get a 50 amp generator inlet with a manual lockout done for $1,000-1,500 and add a cable for $150 and you're done. <$2K vs. nearly $10K for the Powershare + installation but it's your money...
You can run more load from the Powershare, more amps. You also get to stay in bed at night when the power goes out :)
AlmostHuman
Earth
Model X, Cybertruck
Human
It for sure is not cost effective :) We have 4 Powerwalls with solar now, so also waiting for the software update so we can use the truck with the system. The battery in the Cybertruck is more like 9 Powerwalls worth of energy, each Powerwall is only 13.5 user consumable at 3.3 kW charge/discharge rate. Will be rad with the range extender :) I’m hoping they tune the software so it will allow the truck to deliver more power than the Powerwalls when the grid is out to stretch the time the Powerwalls can hang in there. We had the first 3 Powerwalls installed first, all Powerwall 2 units. It was about a year later we had the fourth unit added and it is a Powerwall 2 but with a newer part number. What I noticed is the newer unit is always delivering a little more power than the older units (based on the whole home energy monitoring solution TED) so if feels like they can do it.
Older part numbers: 2012170-00-A
Newer part number: 3012170-05-B
AlmostHuman
Earth
Model X, Cybertruck
Human
You could also just shut the Powerwall off with the switch on the unit.
AlmostHuman
Earth
Model X, Cybertruck
Human
Each PW3 adds 11.5kW of power. Four of them gives 46kW.
Each Powerwall 3 has 13.5 kWh of energy, four of them will give you 54 kWh of energy. Each Powerwall 3 can deliver up to 11.5 kW if configured that way. Our Powerwall 2 units can only deliver 5 kW for example, which is why we started with 3 and ended up with 4, so we can run everything we wanted, including both AC units. :/
Tesla Cybertruck 2025 AWD and Powershare - First impressions IMG_0150
Each Powerwall 3 has 11.5 kWh of energy, four of them will give you 54 kWh of energy. Each Powerwall 3 can deliver up to 11.5 kW if configured that way. Our Powerwall 2 units can only deliver 5 kW for example, which is why we started with 3 and ended up with 4, so we can run everything we wanted, including both AC units. :/
Yah
Energy: 13.5kWh each
Power: 11.5kW each
eswimm
Charlotte, NC
Model Y, Cybertruck
My install was $2,400, so it was a no-brainer. There are a couple different install options. You might want to make sure they haven’t picked an overly complicated and expensive option.
Speedr
Dual Motor Cybertruck
Anyone heard any updates on Powershare with Powerwalls?
AlmostHuman
Earth
Model X, Cybertruck
Human
Another advantage to having a Powerwall in play with solar is you can offset peak energy cost times, of your utility does peak cost. Still takes a while to get the ROI on a system :)
