5th wheel towing
AustroTom
Thomas
Murrieta CA
www.schwaigerdesign.com
Tesla Model S Tesla Model 3 Chevy Silverado 2500HD CT Tri reservation
Artistic metal
Hello All,
Not sure if this has been addressed before but we are planning on towing a 5th wheel and were wondering if the slanted side rails might pose a problem with the trailer turning in tight corners.
Any thoughts?
Advertisement
cyberhunter
Heath
One of the advantages of 5th wheel is the ability to go near perpendicular for backing into tight spots. That would crunch the side rails of the cybertruck. There have been some threads on it here.
Papillion, NE
2013 Ford F350 Platinum, 2010 Toyota Prius, 2021 Tesla Cybertruck (reserved)
Nuclear Operations Analyst
5th wheel may pose a problem but gooseneck trailers designed to not hit the sails are definitely possible.
AustroTom
AustroTom
Thomas
Murrieta CA
Artistic metal
not sure how many (if any), Tesla engineers read this forum but this is definitely a question that will have to be seriously investigated rather than just speculated about. Fivers are after all a big market in the rv and transport world
Papillion, NE
They are a big part of the RV world but keep in mind that almost all Fivers are pulled with one-ton trucks which the Cybertruck is not competing against. There are some Fivers that are pulled by F-150 size trucks but not that many... yet.
AustroTom
AustroTom
Thomas
Murrieta CA
Artistic metal
True. Although from a power standpoint the Tri CT is hardly a 150 anymore.
And I seriously hope the CT will be considered a work horse rather than a Hollywood toy, so towing should be one of the main concerns.
Hopefully Tesla already has different configurations planned (I.e. Low bed, flat bed, box truck etc.), for us to choose once the order window will come around
There are questions as to how one would couple a 5th wheel trailer to the CT and some proposed solutions. As far as power goes I think I calculated that the TriMotor can accelerate a 14,000 lb trailer (the towing limit) from 0 - 60 in 9 seconds. And haul one up a 10% grade at 70 mph with power to spare. Of course the range is no longer 500 mi......
VI Tesla
David
Nanaimo
Model 3, Cybertruck
I've got a 19' Scamp fifth wheel I'm hoping to tow with the CT. Crossing my fingers that with the CT suspension down I can fabricate a hitch that will allow for this. Otherwise Scamp may have to be replaced.
ldjessee
Lloyd
Indiana, USA
reservation for 2 motor Cybertruck, Nissan Leaf, Subau Outback, Kawasaki Vulcan 1700 Vaquero ABS
programmer
If the sides of the trailer on either side of the 5th wheel/bed hitch angle up, then sharp turns would not be an issue.
I could also see some kind of mechanical 'ramp' or screw shape on the hitch/5th wheel, so that as the trailer turns, it is raised as it turns, so that it will not hit the sail/sides of the bed of the CyberTruck.
Papillion, NE
The CT is almost exactly the same size as an F150 though it will be much more capable.
Engineers don't just look at things. They try to figure out why they are the way they are. When an engineer looks at the AWD CT and compares it to the TriMotor it is pretty clear what the 3rd motor and bigger battery are for and that is towing. I should have included this in my comment in No.7. After you draw the conclusion that the third motor and big battery are for towing a couple of checks against the specs quickly confirm that hypothesis.
ReddykwRun
Baldwin Co. Alabama
Tri-motor, tricked out
Retired Military and working on 2nd Ret.
Hello All,
Any thoughts?
Take a look at
www.safetyhitch.com
ReddykwRun
Baldwin Co. Alabama
No longer a problem please see: www.safetyhitch.com
ldjessee
Lloyd
Indiana, USA
programmer
Yeah, that looks like something I do not want to deal with. It would make quickly backing up a trailer less than fun... not that I have tried, but I would probably avoid a 5th wheel if I had to use that.
I assume that if the CyberTruck is popula, people will make 5th wheels that match the CyberTruck, not just in looks, but also it work with its bed.
Advertisement
Advertisement
