Richard V.
- Richard
- Oct 12, 2021
- Quebec
- Chevy Volt 2015
- Retired
- #1
Given that I have ordered a one motor version of the CyberTruck, I need to make a better case for why Tesla would want to keep it as an option now that we are filling the full hands of the Simpsons characters with four options.
1. "Since Mars has less mass than Earth, the surface gravity on Mars is less than the surface gravity on Earth. The surface gravity on Mars is only about 38% of the surface gravity on Earth, so if you weigh 100 pounds on Earth, you would weigh only 38 pounds on Mars." Why would you need so much power when the whole trucks weigh so much less, assuming you would need the truck on Mars? In addition, the one motor version would be the lighter CyberTruck option.
2. "If you can jump one meter (3.3 feet) high on Earth, you would be able to jump 2.64 meters (almost 9 feet) high on Mars." You would need a solid front end for that kind of jumping in unknown Mars land.
3. Maximize the number of CyberTrucks to be loaded into each Starship.
4. Simpler design decreases the number of possible failures, however, a very small backup motor could be added for recovery in case of main motor failure.
5. Reduced number of parts required for maintenance means reduced cargo and inventory to be needed. In addition, this reduces the number of complexities for fixing the Mars CyberTruck fleet by TeslaBots
6. The lowest cost CyberTrucks will favor greater adoption of EVs and be more competitive. Battery range should not have to be married to a CyberTruck motor option. It should be an independent option for all CyberTrucks models IMO.
7. Tesla needs to increase and democratize the adoption of the CyberTruck. A one motor option would greatly help with that view for EV adoption.
8. Lastly, making the one motor version available on Earth will iron out any wrinkles before going to Mars.
