- May 27, 2024
- SE Michigan
- Cyberbeast
Especially since a loose bolt continues loosening. What seemed tight (but wasn't fully torqued) at first can fall off later.The thing is... if the OP can fail to notice a loose door or failing door...
...why isn't it also obvious the person who was supposed to check that door could also fail to notice the loose door?
Like yeah, doors failing suck, and we see it failed. And it might not have opened far enough to see in a camera but freaked OP out because that is a bad situation.
On the other hand...
If the OP can fail to notice a loose door or failing door, the person who was supposed to check that door could also fail to notice the loose door.
Because both of those people are human.
