AlabamaMike
- Mike
- Dec 10, 2019
- Alabama
- Ford F350 Supecab, Tesla Model 3
- Real Estate
- #1
I am attempting to add a column to the Cybertruck Reservation tracker that estimates how long someone will have to wait to receive their order after an eventual factory starts production. The tracker is here:
Cybertruck Reservation Tracker
If you scroll up to the top and right in the google sheet you will see the start of assumptions on ramp up. As I worked on estimates, I quickly realized Tesla is in a tight spot. Even assuming rapid ramp up, Tesla is at least 4 years away from catching up. Here are some key assumptions:
What do people think about above? feedback?
As far as reservations:
What do people think? feedback?
Here is the current state of my uneducated predictions (you can explore the formulas used on the google sheet):
Looking for feedback.
For example we currently estimate over 500k reservations given an assumed cancellation rate and over 600k raw reservations. In 18 months I estimate they will explode to 889k reservations. Between 25% and 35% of those will not follow through (depending on Trim package - see above). This leaves 640k reservations to fill. Tesla will ramp up Tri Motor first to account for low economies of scale and satisfy those Tri Motor reservations within 2 years. However, new reservations will continue to accrue. Tesla will phase in Dual Motor and Single Motor so they are satisfied 6 months later. This gives Tesla 2 years to reach economies that will allow it to produce the Single profitably. By this time Tesla will necessarily be producing 500k units a year. However, reservations will continue to accumulate at a rate of 240k a year so it will take a full year+ to work those off. Then Tesla will have more capacity than reservations and will likely phase in Cyber variants that can use the same production lines. However, for the purposes of helping to determine how long someone will have to wait, the ramp during the first 2-3 years is key.
Any hard data to help steer this to be more realistic (if t is not)?
Do you think Tesla will look at the dollars on the table ($50billion+) and ramp up a Cyber factory at an insane speed (faster than China) so as not to loose the reservations?
It is pretty clear that Elon is correct when he says there is enough demand to take 4-5 years to catch up
Update (4/20/20) - methodology is now posted and updated online here:
https://sites.google.com/view/cybertruck-reservation-results/production
Have changed some of the numbers above based on feedback.
- Tesla will start with Tri Motor and move to Dual then Single Motor as economies of scale improve.
- A potentially large number of reservations will cancel out of frustration or may not have the ability to follow through
- Even though the Cybertruck will require considerable new methods of production (along with their own production h*ll), tesla will ramp up quickly: 100k+ within 12 months; 250k+ during second year; 500k+ during year 3 and 4.
- We are 18 months away from the first unit being produced for sale. (6 months to ground breaking; 12 months after that to deliver 1st truck).
- reservation rate will quickly hit a steady state of 10% of the US truck market (about 240k a year). Right now the reservation rate is running around 600k a year so this is conservative.
- reservations will continue to build however 25-35% of those will eventually cancel. Does anyone know how this compares to model 3 cancellations?
- Tesla will have to go for it as far as maxing out capability (500k per year) in order to catch up with demand in the next 5+ years; after that they will have to adapt some lines to additional Cyber Vehicles (maybe vans? or cyber cars?) to scale back to a steady state of around 240k per year. If Tesla simply tries to asymptotically ramp to demand it will take 10 years to catch up and people will cancel orders in droves.
Tri Motor | Dual Motor | Single Motor | Total | Cumulative | Est Reserv 18m from now | |||||
Monthly Rate | 25% | 30% | 35% | <- Additional cancel | 288,176 | 307,969 | 42,166 | 638,311 | 889,061 | 18 month from now |
0-3 month | 3,000 | 0 | 0 | 3,000 | 9,000 | 0 | 0 | 9,000 | <- Total Production | |
3-6 month | 6,000 | 1,000 | 0 | 7,000 | 27,000 | 3,000 | 0 | 30,000 | ||
6-9 month | 10,000 | 4,000 | 0 | 14,000 | 57,000 | 15,000 | 0 | 72,000 | Total Reserv | |
9-12 month | 15,000 | 8,000 | 0 | 23,000 | 102,000 | 39,000 | 0 | 141,000 | 875,561 | 30 month from now |
12-24 month | 15,000 | 15,000 | 0 | 30,000 | 282,000 | 219,000 | 0 | 501,000 | 1,112,811 | 42 month from now |
24-36 month | 16,000 | 19,000 | 7,000 | 42,000 | 474,000 | 447,000 | 84,000 | 1,005,000 | 1,350,061 | 54 month from now |
36-48 month | 16,000 | 19,000 | 7,000 | 42,000 | 666,000 | 675,000 | 168,000 | 1,509,000 | 1,587,311 | 66 month from now |
mix on final year -> | 38% | 45% | 17% | 44% | 45% | 11% | <- cumulative mix |
