samroy92
- Sam
- Apr 20, 2021
- San Diego
- Website
- samroy.io
- 2018 Model 3, CT Tri/Quad FSD
- Head of Technology (SW, DevOps, IT, Security)
- #1
TLDR Edit 2 (7/20/23):
~1450 Cells
~400 Wh/mi efficiency
~100-110 Wh per Cell
Not including range buffer (3-5 kWh)
1450 Cells * 110 Wh = 159,500 Wh, in other words ~159kWh. If we assume 400 Wh/mi of driving efficiency this would give us an estimated EPA range of 397miles.
If Cell capacity is only 100 Wh for Gen1 CT the same calculations would yield: 362 miles of range. Not including range buffers.
Hi everyone, I have been wanting to put these predictions together for a while and now we finally have some concrete data. We do still have to make some assumptions on the Cybertruck itself as well as what 4680 yields will be in a year so this will be a range. TLDR at bottom.
Lets start with what we know.
The standard range model Y has 34/35 cells in a row (literally counting them from the Munro video above), 6 cells in a group, 4 groups in a structural pack.
828 cells at around 95 Wh per cell = ~78kwh for the texas made model Y. From insideEVs: "4, 23S9P modules making a 92S9P pack".
3.8V per cell (per UCSD teardown). 92 in series = 350V, 9 of those in parallel for the 78kwh.
46mm diameter cell is approx == 64 inches long on a chain of 35 cells. Or around 5 1/3 feet.
STANDARD RANGE Model Y battery pack
4 groups
3 bandoliers per group
34/35 arrangement cells per band
23S9P * 4
23S9P == 34*3 + 35*3 = 102 + 105 = 207 == 20.7kwh per group
828 total cells
35 x 4680 cells in the longest string. 46mm diameter ~ 1.811 inches.
model Y wheelbase == 113"
cell string length = 63.5"
string length ratio to wheelbase == 56%
Warning: Big assumptions ahead
Assumptions
The case of 350-500V Cybertruck
LONG RANGE CYBERTRUCK ~437V
5 cell groups
3 bandoliers per group (pair of cell strings)
23S15P = 345cells per group, 115 cells per band
115S15P total pack == 1725 cells
57/58 per band
345 x 5 = 1725cells == ~172kwh per pack = 430mi/range
CT estimated wheelbase = 149"
Ford lightning wheelbase = 145"
cell string length = 105"
string length ratio to wheelbase = 70.4%
LONG RANGE CYBERTRUCK ~376V (More realistic)
3 groups
5 bands per group
33S15P = 495 cells per group * 3 = 1485 cells == 375V pack == 149kwh == 375mi/range
49/50 bandollier == 99 per band
cell string length = 90.5"
string length ratio to wheelbase = ~60%
15 pairs or bandolliers vs 12 on the model Y standard range
49/50 length bands instead of 35/34 on the model Y standard range
The case of 800-900V Cybertruck
LONG RANGE CYBERTRUCK ~722V
5 groups
3 bands per group
47,48 == 95 cells per band
38S8P groups x 5
190S8P = 1520 cells = 152 kwh == 722V == 375mi/range
48 cells * 1.811" = 87" string length == 58% ratio
LONG RANGE CYBERTRUCK ~850V
5 groups
3 bands per group
53,52 length = 105 cells per band
45S7P * 5 = 225S7P == 1575 cells == 158kwh == 855V == 395mi/range
53 cells * 1.811" = 96" == 64% ratio (starting to get unrealistic again)
When visualizing these packs think of this:
With an extra group. And longer.
Cell Yields are improving.
Right now the most accurate capacity estimate of the 4680 yields and cell material. If we conservatively feel that when Cybertruck production starts we are achieving 110-120wh per cell. Our realistic range estimate becomes:
1485 Cells @100wh/cell:
~149kwh * 2.5mi/kwh = 375mi/range
1485 Cells @120wh/cell:
~177kwh * 2.5mi/kwh = 442mi/range
1520 Cells @120wh/cell with the 190S8P 722V pack (my prediction):
~181kwh * 2.5mi/kwh = ~450mi/range
TLDR; I think we will realistically see375-450 miles of range 325-400 miles of range on the Cybertruck depending on 4680 yields in mid-2023. I think pack size will be between 1450-1520 cells, my prediction is a 190S8P (722V) configuration.
TLDR Edit 1: I am revising my range estimates down due to empirical evidence of UCSD teardown of 4680 cell. I think it is likely that yields on Cybertruck 4680 will be in the 90-100Wh per cell range. This puts pack capacity at 130.5kWh - 152kWh or 326mi-380mi
It seems that 100-110Wh per gen2 cell is fairly realistic considering the recent comments on earnings call saying that their latest 4680 cells are 10% increase in energy density.
~1450 Cells
4 groups
23S9P * 4
828 total cells
Assumptions
- Current 4680 cell yields ~100Wh at 3.8V
- Cybertruck will have a single layer pack (not double stacked)
- Cybertruck is wider than Model Y
- Cybertruck has a wheel base of 145-149"
- Cybertruck efficiency is 400wh/mi
5 cell groups
57/58 per band
This pack length seems too long to fit the dimensions of the Cybertruck, therefore seems unlikely we could see a pack with more than 1600 cells.
3 groups
5 bands per group
This pack length seems way more realistic in the 400V range
5 groups
3 bands per group
38S8P groups x 5
5 groups
3 bands per group
