Cybertruck Roof Dome
EVCanuck
M
Montreal, QC
Mostly sedans and never owned a truck. Now CT is all I want!
Cybertruck's roof dome will obviously be very voluminous due to CT's form. I believe Elon stated that roof top light will be standard on all variants. Obviously there will be interior dome lights, but I wonder what else will be housed in that dome (any other electronics, WiFi antenna, elements of HVAC). Just trying to start a speculative discussion here.
Sputter
Herbert
Rockville, Maryland
2019 Model 3
I still would hope that some method could be engineered that would enable the tonneau cover to be withdrawn up into that space instead of curling down behind the back seat. That way, the cover could be used as a sun shield when parked in Arizona and would allow my dog free rein of the cab. Plus, it'd make the vault more usable and spacious. I think it'd be beneficial for camping also. But hey, I know, I know, the tonneau cover is too wide to do what I want. sigh...
Corriveau
Puerto Rico
2010 Ford Explorer
The wiring required to power the propeller/rotor?
Bankercobb
William
Model 3, Cybertruck Reserved
Marine
I have the model 3, the glass roof let's minimal light in. My dog and children have no issue with it. Go take a test drive in one, they are fantastic. And if you feel its still somehow too much you can buy blackout shades, I'm sure they will be available for CT. At or shortly after launch.
Sasmania
Steve
Scottsdale & Flagstaff AZ
P3, Model X (Probably replaced by PY later in the year) CyberTruck Tri
FlagstaffRentalCabin.com & TeslaRenter.com
I just hope they carve out some space for a built-in Starlink Dish that's flush with the existing roofline but somehow still connects. I'd give up a bit of that view for the privilege as it really would only block the view when looking straight up while in the front row. It would be a bit more obvious in the back row, but screw them. Lol
...enable the tonneau cover to be withdrawn up into that space instead of curling down behind the back seat. That way, the cover could be used as a sun shield...
Well, you could always adhese some flexible solar cells up there. Especially if they allow us to tap into whatever system they're using to feed to solar option to charge the battery ^-^
The Starlink dish always will need space to move around because of the way it uses a narrow, low-power beam so... You might need a little globe up there in the corner or something.
CybrTrkOregon
Alex
Oregon
Toyota Sequoia
Software Developer
I do not believe the starlink dish itself moves. It is, if I remember correctly, a phased array antenna and components within the dish "move" while the entire dish stays stationary (unless of course it is on a moving platform like a ship, plane, or truck)
Sirfun
Joe
Oxnard, California
Toyota Avalon, Toyota Seinna, Ford E-250
Retired Sheet Metal Worker
I wonder about a portable one with plug-n-play, that you could put on the roof rack when CT is parked.
Blue Steel
MP
Portland OR
Model Y, Fiat 500e
Mgmt
The dome lights on the prototype were LED strips located above each door. I bet that will carry over to production.
I highly doubt any HVAC ducts will run that high. Perhaps an antenna or two.
I think the bird cage in the Model X is most similar. You’re going to have a rear view mirror, camera cluster. Your visors will attach on either side to the A pillars. And that’s about all I expect to see above the screen. Gotta have a hazard light button mounted somewhere.
Advertisement
Advertisement
