greggertruck
- g
- Mar 30, 2022
- USA
- Dual-CT
- #1
I feel for you. Happens to the best of usWind tunnel testing!edit: (at least that's what i think the white tunnel is)
Just give me my truck!
That is not a wind tunnel, it is a prototype for the new, even bigger BAW (the e-BBAW). Elon said "why wipe off the water when you can just blow it off?" and the e-BBAW was born.BAW testing.
It’s not technically a wind tunnel. I would call it a semi-controlled airflow simulator. A wind tunnel is: (1) a tunnel, (2) generally closed, (3) the airflow is highly controlled, and (4) the device is highly instrumented. The facility at Giga Austin is a mobile unit to get ad hoc measurements at manufacturing facilities rather than sending them out to a real wind tunnel. They need not be accurate as they are intended for manufacturing tweaks.Wind tunnel testing!edit: (at least that's what i think the white tunnel is)
Thanks for killing the mood, ProfessorIt’s not technically a wind tunnel. I would call it a semi-controlled airflow simulator. A wind tunnel is: (1) a tunnel, (2) generally closed, (3) the airflow is highly controlled, and (4) the device is highly instrumented. The facility at Giga Austin is a mobile unit to get ad hoc measurements at manufacturing facilities rather than sending them out to a real wind tunnel. They need not be accurate as they are intended for manufacturing tweaks.
I am also happy to see anything Cybertruck, this included. I was unhappy when folks on Joe's Patreon page insisted on calling it a wind tunnel, and I apologize for my training and work history as an aerospace engineer but that is just the way it is.Thanks for killing the mood, Professor
You do you, brotherI am also happy to see anything Cybertruck, this included. I was unhappy when folks on Joe's Patreon page insisted on calling it a wind tunnel, and I apologize for my training and work history as an aerospace engineer but that is just the way it is.
Would this be used to test for wind noise in isolation from road noise?It’s not technically a wind tunnel. I would call it a semi-controlled airflow simulator. A wind tunnel is: (1) a tunnel, (2) generally closed, (3) the airflow is highly controlled, and (4) the device is highly instrumented. The facility at Giga Austin is a mobile unit to get ad hoc measurements at manufacturing facilities rather than sending them out to a real wind tunnel. They need not be accurate as they are intended for manufacturing tweaks.
We accept your apology for your aerospace engineer training.I am also happy to see anything Cybertruck, this included. I was unhappy when folks on Joe's Patreon page insisted on calling it a wind tunnel, and I apologize for my training and work history as an aerospace engineer but that is just the way it is.
You shouldn't apologize. Everyone here should be happy about what you're saying. It means they are tweaking the production line, not the design of the vehicle. That should be obvious as they design in Cali not Texas and presumably the design is long since finished, but your tidbit says this is all about getting things going to crank out trucks.I am also happy to see anything Cybertruck, this included. I was unhappy when folks on Joe's Patreon page insisted on calling it a wind tunnel, and I apologize for my training and work history as an aerospace engineer but that is just the way it is.
