starship2021
- Chris
- Jun 8, 2021
- MA
- considering cybertruck - no car now.
- self emp
- #1
The Cybertruck I've read has a 240VAC, 30V amp outlet. Where could I locate the full specifications?
Can the 240V inverter remain in the on-state for an extended period of time (so long as there is energy in the battery) or does it automatically turn off after several hours? If it remains on - this allows the Cybertruck to replace a portable ICE generator that could be connected in a grid outage to one's home.
Presently I've implemented AC coupling of my solar inverter to a marine inverter (Magnum Energy MS4048) that provides a grid voltage reference by connecting it to the ICE generator input at my home. This enables the solar inverter to continue operation when the utility grid is disconnected and then to suppememt the batteries with solar power. The advantage of the marine inverter over a generator is that it is bi-directional meaning that when the solar power production is greater than the home load, power will flow 'backwards' though the marine inverter INTO the 10kWh battery pack.
Is the Cybertruck 240VAC inverter capable of supporting bi-directional operation as is required for solar AC-coupled applications?
