Administrator
Administrator
Staff member
Cybertruck Owners Club
CYBERTRUCK
Via Teslarati
Tesla plans for Cybertruck-specific Supercharger spaces
September 23, 2020
Tesla is preparing for the eventual rollout of the Cybertruck by offering plans on wider, longer charging spaces at Supercharger stalls. A recent proposal by the Pasadena Water and Power Department in California shows plans to install 20 Tesla charging points within a city-owned lot. A recent presentation with Pasadena Officials showed that at least six of the spaces would be wider and longer to make way for the Cybertruck’s size.
The location of the new Supercharger station is proposed to be set at 85 E. State Street in Pasadena, CA. The chargers will be Tesla’s V3 250 kW-capable stalls. The five-year term with an option for a two-year extension is outlined in the Agenda Report, which also shows the number of charging spaces available at the new site. The documents were spotted by Tesla Motors Club member RubberToe.
Cybertruck Cybertrucks Will Have Larger Parking Spots at Tesla Superchargers tesla-charging-cybertruck-space-render-567x312
Cybertruck Cybertrucks Will Have Larger Parking Spots at Tesla Superchargers tesla-cybertruck-spots-location-420x312
Cybertruck Cybertrucks Will Have Larger Parking Spots at Tesla Superchargers tesla-pasadena-charging-render-991x533
“Under the recommended Agreement, Tesla will install and operate 20 Tesla Supercharging charging stations at their expense. PWP will install up to seven DCFC EV charging stations, and up to 20 Level 2 chargers, that may be used by all types of electric vehicles,” the document states.
According to the plans that are detailed on blueprints for the site, at least fifteen Tesla V3 Supercharger stalls will be available at the site, with six of them being possible “Cybertruck wide spaces.”
Cybertruck Cybertrucks Will Have Larger Parking Spots at Tesla Superchargers tesla-pasadena-supercharger-cybertruck-spaces
With the Cybertruck having massive dimensions that were somewhat questionable for residential garage parking, it seems logical that new Supercharger locations prepare for the presence of Tesla’s first pickup with these newly-designed spots. The Cybertruck is massive compared to the company’s other vehicles, and revising some spots for the future is a wise idea.
It also appears that the Pasadena Water and Power held a meeting with local government members to look at the possibility of the new Supercharger station. The presentation that was given to the members indicates that the new station “will include 6 Spaces for new Cybertruck.”
Cybertruck Cybertrucks Will Have Larger Parking Spots at Tesla Superchargers tesla-cybertruck-spots-charging-meeti
The preparation of new charging spots that will be appropriate for the Cybertruck is an indication that Tesla, along with cities that will build new stations, is readying for the new pickup. Traditionally, large vehicles and trucks can have issues finding adequate space because of the sheer size of a car. If other vehicles were to be parked in spaces that are adjacent to where a Cybertruck is attempting to park, it could be an inconvenience. Therefore, larger spaces are undoubtedly the more precautionary and responsible move.
The Pasadena Municipal Services Meeting document is available below.
Seems odd to build these specifically wider stalls but no mention of trailer pull thru’s?
Yeah. Especially when there are back to back stalls that could be used that way.
I have no towing plans, but clearly others do. It wouldn't be hard to put two chargers so two trucks or a truck and a trailer could charge.
Ehninger1212
Jake
Houston, TX
Architect/Fabricator
LOL... if you cant park the NORMAL sized cybertruck in a NORMAL sized parking space you should reconsider your purchase.
I seriously dont understand everyone's obsession with the Cybertruck so called "massive dimensions"... getting old quick. Please compare to all other full size trucks on the market.
I see V3 rows of respectively 8., 2 and 9 stalls totaling 19. It is hinted that the row of 8 may become a row of 6 wider stalls to accommodate CT's. This would make a total of 17 stalls. But the plan calls for 20 Suoerchargers. where do the extra 1 or 3 Superchargers go? I desperately want the answer to be that some of the stalls will have two chargers to serve the two ports which I have been hoping the CT will have in order to allow effective charging at 500 kW. A single 250 kW charger would, assuming 400 Wh/mi, mean 625 miles per hour (at the beginning of a charge at least). Assuming we normally charge every 200 - 300 miles and that all we want to replenish is that which we have just used that would mean charge times of 30 - 40 minutes (allowing for taper). If two chargers can be simultaneously connected then those times drop to 15 - 20 minutes.
Waresdom
Wisconsin
2012 Chevy Silverado
I agree. This is a standard size in the midwest.
lqdchkn
B
TX
CT
Wider not necessarily needed IMO but pull trough pretty important as other have mentioned since it would be a major PITA to charge when having a trailer attached
Ehninger1212
Jake
Houston, TX
I definitely agree, they do need some pull through stalls. At least one spot capable of it at these larger charging sites. But I personally wont be doing much traveling with a trailer.
A truck should be easy enough to fit in a normal parking spot...
...But gas station filling spots aren't small, either, and you need room to move around the truck while it's charging.
And they've talked about maybe having a special charger for the truck and semi. Maybe that's where the extra superchargers go?
hridge2020
Henry
Central Coast CA
Tesla
Rocket/Missile/Spacecraft/Air Defense Scientist
  1. So if other models are charging in cybertruck stalls is it allowed? (Probably will be abused by other owners of other models, to use the extra-large areas also)
2. Just park-like other large RVs, trucks hauling trailers, etc. that park in grocery/Costco, parking lots while there getting there business/shopping done. (Everyone will understand ?? :unsure: )
Cybertruck Cybertrucks Will Have Larger Parking Spots at Tesla Superchargers Cybertruck trailer chargi
Luke42
Luke
Illinois, USA
Tesla Model Y, GMC Sierra Hybrid 3HB (2-Mode)
Transitioning from a regular car to a full-sized pickup truck is daunting.
I prefer a small cars, but buy/sell/trade used cars whenever my needs change. Since 1995, I'm on my 4th pickup truck -- and transitioning from a small car to a full-sized pickup truck is daunting, even when I've owned and driven one within the last 10 years (and driven much bigger vehicles on occasion).
Yes, a full-sized truck will fit nearly everywhere that a regular car will. But you've got to think and plan more, and be more precise about your visual references and sight-picture.
If you've never done this before, it is a big deal.
I am hopeful that Autopilot and cameras will make it less so than when I'd borrow my dad's truck. I was still driving it until a couple years ago, when my mom finally said goodbye to it. (I was the only one driving it.)
I've seen what Ford can do in their Flex and expect in two years Tesla will have it figured out. They're already adding features into their system they'll need.
