Tinker71
- Ray
- Aug 8, 2020
- Utah
- 1976 electric conversion bus
- Project Manager
- #1
Who thinks Tesla will double stack the 4680 cells for the long range version?
I just can't see it.
1.) Unless the lower range version is a lot different than the long range version there will be a 80 plus mm void or wasted space on the standard range models.
or
2.) There would be a deeper belly (less clearance on the long range)
3.) Many of the interior components would be different if the floorboard height was different between models. Tesla doesn't like to do that.
4.) A double stacked structural battery pack would be much more complicated than single stacked.
I suspect that Tesla will max out the range based on single stack battery. That will likely be less than 500 miles. Over the next couple years as the 4680 power density improves Tesla will increase the range. Tesla can always remove rows of cells for shorter range vehicles, but it may not be worth it at the start of production. They might start with one battery pack.
Note that the Lucid high range model gets part of it's extra range by double stacking modules which negatively affects rear passenger comfort.
Maybe Tesla will use the space under the seats for batteries to avoid a complete double stack at the floor board areas.
or
