firsttruck
- #1
Increasing initial costs, maintenance costs, downtime costs of diesel ICE pollution emission controls - Another advantage for Tesla Semi & other EV trucks.
Diesel Particulate Filters: Blessing and Curse
January 23, 2015
By Tom Berg
https://www.truckinginfo.com/155909/diesel-particulate-filters-blessing-and-curse
Diesel particulate filters are one of the major additions to exhaust systems in recent years, and they are a blessing and a curse. Used since 2007 to meet EPA regulations, DPFs strip soot and ash from the exhaust stream. Added to exhaust-gas re-circulation already used to reduce nitrogen oxides, DPFs greatly cleansed exhaust and eliminated the characteristic diesel smell. Addition of urea injection in 2010 and advancements in combustion efficiency along the way result in exhaust so clean that it can barely be measured. That’s the blessing.
The curse comes from the extra maintenance and repairs required to keep the systems operating, along with unscheduled downtime, stranded drivers and missed deliveries, fleet managers say.
Heat for an active regen is created by adding fuel to exhaust gasses, and the fuel — sometimes called “hydrocarbons” — is ignited just ahead of the DPF. Temperatures of up to 1,100 degrees Fahrenheit result, burning out the soot. When a dash light warns a driver that a regen is needed, he must pull over soon and let it happen. If he doesn’t, electronic controls, which know via sensors that the DPF is plugged up, will cut engine power and eventually shut it down. The engine fast-idles during an active regen, so the truck must remain parked. Heat from the tail pipe can ignite grass below or ** overhead tree branches ***, so drivers need to park the truck away from such flammable objects.
A new DPF costs about $5,000, and a reconditioned one about half that. A recon unit works almost as well as a new one, and suppliers have exchange programs where a dirty DPF plus a service charge is traded for a cleaned one. Or the truck’s owner can wait for his own DPF to be serviced so it stays with the truck. A damaged DPF has almost no value and the owner must buy another. The ceramic honeycomb structure can suffer cracks from road shock or accidental dropping, or melted by excessive heat.
commenter 1. Anthony Bulygo May 05, 2015
Missing is a critical issue. As stated, the ash removed from the DPF is considered a Hazardous Material. Hazardous because the particles of ash are so small that they can be absorbed through the skin and if inhaled can be attached to the linings of the lung and not expelled. If you have coolant entering the DPF during a major engine failure, the water in the coolant will chemically change the ash to a concentrated acid that can severely injure the mechanic. Be careful out there and use your protective gear. when servicing the units. ALL ASH MUST be captured and held for HazMat pickup. So, if you think you can just remove it and blow it out with the air hose at the shop, reconsider the consequences. Be safe. And, yes, the EPA mandates that the DPF registered to the vehicle MUST remain with the vehicle for life. No exchanges, except for totally failed units. Application must be made to the EPA here in CA for DPF Serial Number changes.
January 23, 2015
By Tom Berg
