Exterior Cleaning : Use isopropyl alcohol wipes
A pretty big statement is at the end of the article
Use isopropyl alcohol wipes (such as those used to clean glasses or screens) to clean away small stains.
From Exterior Cleaning (tesla.com)
To prevent damage to the exterior, immediately remove corrosive substances (such as grease, oil, bird droppings, tree resin, dead insects, tar spots, road salt, industrial fallout, etc.). Do not wait until Cybertruck is due for a complete wash. If necessary, use denatured alcohol to remove tar spots and stubborn grease stains, then immediately wash the area with water and a mild, non-detergent soap to remove the alcohol.
Note
It is normal for the stainless steel exterior to mature over time, resulting in minor changes to the reflective properties and color of the metal.
Dents and Scratches
The stainless steel exterior of Cybertruck is more resistant to dents and dings than most other vehicles. However, Cybertruck does not have a clear coat on the surface of the exterior body panels, meaning any scratches that appear are in the stainless steel panels themselves. Anyone performing scratch repair should refer to the applicable "Exterior Stainless Steel Panel Refinishing" procedure within the Collision Repair Manual on service.tesla.com. In addition, do not use, and/or immediately remove, chemical, corrosive, or non-pH neutral substances (including but not limited to: acidic liquids or materials, grease, oil, tree resin, dead insects, tar spots, road salt, industrial fallout, etc.) as they can cause corrosion on the vehicle's exterior.
CAUTION
Tesla is not liable for any damage caused by failing to refer to official guidance.
Keep the exterior cameras free of dirt, condensation, or obstructions. These substances can cause unclear pictures or Autopilot and safety features to stop working (see Cleaning a Camera).
Follow these steps when washing the exterior of Cybertruck:
  1. Before washing, flush grime and grit from the vehicle using a hose. Flush away accumulations of mud in areas where debris easily collects (such as wheel wells and panel seams). If salt has been used on the highways (such as during winter months), thoroughly rinse all traces of road salt from the underside of the vehicle, wheel wells, and brakes.
  2. Mix a mild, pH-neutral soap (such as car shampoo) with water until it gets soapy.
  3. Soak a soft cleaning sponge in the soap mixture and hand wash Cybertruck.
    CAUTION
    Some cleaners and car shampoos contain chemicals that can cause damage or discoloration, especially for plastic trim pieces, exterior lights, or camera lenses. For example, some car cleaning formulas contain hydroxide or other highly alkaline or caustic ingredients that can damage exterior components. Do not use acidic products either. Damage or discoloration resulting from cleaning products is not covered by the warranty.
  4. After washing, rinse with clean water to prevent soap from drying on the surfaces.
  5. Dry thoroughly with microfiber cloths (ensure the cloths are clean of sand, dirt, rocks, etc.), one in each hand, rotating in circular motions until the surface is dry.
For a waterless wash:
  1. Hand wash using a non-ionic pH-neutral waterless wash with a high quality microfiber towel.
  2. Dry any streaks thoroughly with a chamois.
  3. Remove oil and grease with an organic solvent, such as alcohol or ethyl alcohol.
    Note
    Do not use alcohol or ethyl alcohol on the head or tail lights.
For spot cleaning: Use a glass cleaner and microfiber cloth. Spray glass cleaner and wipe in a zig-zag motion when cleaning large areas, such as entire panels.
Note
Tesla does not recommend taking Cybertruck through an automatic car wash.
Synchronicity786
O
Charlotte, NC
Ford Bronco, Tesla Cybertruck
Physician
My god. Had anyone formulated a method to clean their truck yet? Specific products?
Outdoors
Outdoors
North West Montana
S,3,Y,C
I like good old high pressure water. No soap.
