Last summer I drove through the Gorman wildfires, engaged BDM early on and thought it did a great job filtering out the smoke. I did start to smell it after about 10-15 minutes though.HEPA filter replacement every 2 years, or every year in cases of off-road/dirt road driving or excessive pollution
Haha! That would be a real trick if it could eliminate 99.9% of the odors! It's mostly a HEPA particulate filter. It can remove virus and dust, and some odor, but not odor from combustion gases to any degree. To do that you would need pounds and pounds of carbon or other absorbent media and it would have to be replaced frequently.How often do these normally need to be replaced?
Drove through an evacuation zone today due to a fire and even with bio defense mode activated you could smell the fire inside the car. Thought that it eliminated 99.9% of odors?
Bio defense mode just sucks in even more outside air. Best to turn off the ac or run in recirculate mode.How often do these normally need to be replaced?
I noticed every time I turn it on it’s on full blast.Haha! That would be a real trick if it could eliminate 99.9% of the odors! It's mostly a HEPA particulate filter. It can remove virus and dust, and some odor, but not odor from combustion gases to any degree. To do that you would need pounds and pounds of carbon or other absorbent media and it would have to be replaced frequently.
Even so, a HEPA filter is a huge benefit to remove particulates, allergens and infectous organisms, even if some smells come through. It will be most effective on odors if you keep the fan speed low. That will reduce the velocity of the intake air through the filter media.
If you were willing to replace the big filter every month, you would get more odor reduction but not 99.9% and that's just not very practical for most people. I like that I can keep the interior nearly dust free simply by keeping the windows up whenever I'm in traffic or dry, dusty conditions.
I think the official schedule is to replace it every 2 years unless in dusty conditions, then every year or as needed. In very dusty areas with a lot of hours of use I could see replacing it every 3 months. But where I live in the damp PNW my Tesla filters easily go two years.
Common sense says replacement interval has to do with how hard you run the fan too. The more air you pump through the filter, the sooner it should be replaced. That said, the Cybertruck is the first vehicle I've owned that has an "upside down" HEPA filter. That means larger particles wont plug the filter up, they will fall back down into the air intake, which could extend your filter life depending upon what is getting drawn into your air intake. My Model 3 HEPA filters are far smaller and get filled with needles, insects, twigs and dry leaf crumbles (because they are not "upside-down").
Yes it is full blast sucking in outside air.Best to keep it off or in articulate mode vs biodefense?
Right. It says when it’s “on” but is it better to have it in biodefense mode or completely off when driving through fire zones?“The HEPA filter ensures the best quality air inside the cabin whenever the climate control system is on and outside air is entering the cabin (recirculate is off). The HEPA filter is extremely effective at removing particles, including pollution, allergens, bacteria, pollen, mold spores, and viruses. When you engage Bioweapon Defense Mode, the positive pressure inside the cabin minimizes the amount of outside air that can enter the vehicle.
Note
Some gases, such as carbon monoxide, are not effectively removed by activated carbon.”
https://www.tesla.com/ownersmanual/cybertruck/en_us/GUID-CFA216A5-F2CC-416F-97E8-8560E0CC4161.html
Probably “recirculate” is the right answerRight. It says when it’s “on” but is it better to have it in biodefense mode or completely off when driving through fire zones?
If it's just smoke, I would probably just run a low to medium-low fan speed because I don't think a lot of air leaks around the door and window seals anyway, and I would want the lower volume of air through the filter for better filtration of tiny particles and absorption of gases. Putting recirculate on would likely further improve filtration (and thus inside air quality) as long as it's designed in such a way so as to not depressurize the cabin (which could potentially increase air infiltration from outside). I assume the system is engineered to keep (at least) a slight positive pressure in the cabin no matter which mode you are in.Right. It says when it’s “on” but is it better to have it in biodefense mode or completely off when driving through fire zones?
Silly questions:Biodefense mode works because of the pressure created by the maxed fan speed. It creates a positive pressure in the cab, forcing other seams around the vehicle to become sealed ingress. Clean rooms work the same way.
Positive pressure rooms (the truck) are protecting environments. Negative pressure rooms are isolation environments. Keep the fan maxed.
For those interested:
https://airinnovations.com/blog/negative-positive-pressure-rooms-hospital-infection-control/
Interesting questions! Yes, it does bring outside air in, which is why HEPA filters are so important. Keep in mind that pulling air into the vehicle is necessary to create a positive pressure environment. Recirculating air cannot create a positive pressure room in same way that you can't pull yourself off the ground by pulling your bootstraps--you need to be constantly adding new clean air in order to create a positive pressure.Silly questions:
Does it also bring in outside air into the vehicle through the filter? There is no way right now of creating that positive pressure in the car with the fan on only and not bringing in any outside air? Would this be recirculate mode?
