Aces-Truck
- Kevin
- Apr 25, 2020
- Snohomish County, WA
- 2024 AWD Cybertruck, 2025 MY
- Mechanical Engineer
- #1
I've started thinking about the 48V voltage system. I intend to run a 50W mobile Ham Radio in my CT. So now I have some head scratching as to how to do it. For those not familiar with Ham Radio, there are several Radio "Bands" that we use. The long distance guys do HF bands (High Frequency). All the electrical Hash that any EV puts out, will likely make that type of use "iffy" at best. But I would mainly be doing UHF/VHF bands. These can often handle the hash. But the issue for me will be all the radios out there are 12VDC. I see they make Buck Converters that can convert 48VDC to 12VDC. And they are quite cheap. I've seen models that can handle 10A at 12V on the output (120Watts) for $20. But how likely are we to be able to just tap into the 48V wiring? This is something Winches would have to deal with as well.
The other way to do this is to use the USB-C ports inside the cab. I'm surprised they are only 60W. But most Mobile radios are 50Watt. I wonder if we'll be able to find USB-C to 12VDC adapters?
