How Silverado EV Stacks Up Vs Cybertruck, Rivian, Hummer, And Lightning
FutureBoy
Reginald
Kirkland WA USA
Toyota Sienna
Financial Advisor
How do these five electric trucks compare on paper?
Tesla Cybertruck How Silverado EV Stacks Up Vs Cybertruck, Rivian, Hummer, And Lightning t-silverado-ev-vs-cybertruck-lightning-and-rivian
Jan 06, 2022 at 4:58pm ET
By: Jeff Perez
Electric trucks: so hot right now. With some of them reaching dealerships in 2021, others arriving early this year, and at least two more on the way in the years to come, soon the market will be saturated with all varieties of battery-powered pickup.
With so many options to choose from, you're probably wondering which EV truck is worth your money. Until we're able to get all of them together for a proper comparison test, it's impossible to definitively tell you which one is best. But, we can at least peruse the specs sheet and look over the stats so that you have an idea as to what each one offers.
The Chevrolet Silverado EV is the latest to join the fray, making its virtual debut as part of the 2021 CES show in Las Vegas this past week. But the list of contenders also includes the Ford F-150 Lightning, the GMC Hummer EV, the yet-to-reach-production Tesla Cybertruck, and the Rivian R1T. So let’s see how they stack up.
Price
How much are these battery-powered trucks going to cost? Some of them, like the Rivian and Hummer, aren't attainable to the everyman – but they do come loaded with features, unlike some of the more affordable trucks. The R1T starts at $67,500 for the base Explore trim, while the Adventure model brings the asking price up to $73,000. The GMC Hummer EV Edition 1 is even pricier, asking $108,700 out of the box. But the base model will start at $79,995 when it goes on sale in spring of 2024.
On the more attainable side, the Tesla Cybertruck has a rumored starting price of $39,900 for the base single-motor, rear-wheel-drive model (if that's still happening). The Ford Lightning Pro starts at $39,974 (before $1,695 in taxes and fees), with the top-end Platinum trim asking $90,874. The Silverado EV, when it goes on sale, will cost $39,900 (before fees) for the base Work Truck trim and $1056,000 for the top-end RST model.
Base Price
Chevrolet Silverado EV$39,900
Ford F-150 Lightning$39,974
GMC Hummer EV$79,995 / $108,700 (Edition 1)
Rivian R1T$67,500
Tesla Cybertruck$39,900
As far as availability is concerned, the GMC Hummer EV and the Rivian R1T are the only two trucks that made it to customers in 2021. Although, technically speaking, Hummer only sold one (1) example in 2021. Nonetheless, the Lightning should hit the road early this year – but we will have to wait for the other two.
Tesla says the first examples of the Cybertruck should roll off the production line sometime this year, following months of delays. And Chevrolet says the First Edition variants of the Silverado EV will make their way to customers in 2023, while the rest of the model line won’t debut until at least 2024.
Capacity & Range
Naturally, you want to know what powers each of these machines. In the case of the Silverado EV and GMC Hummer, those trucks use GM's new Ultium battery pack. While Chevy hasn't released specifics on the Silverado EV's overall capacity, we can safely assume that it holds the same 200.0 kilowatt-hours as the Hummer in the top-spec RST trim. The base Work Truck, Chevy says, will have a smaller battery pack and capacity.
Tesla Cybertruck How Silverado EV Stacks Up Vs Cybertruck, Rivian, Hummer, And Lightning silverado-ev
Tesla Cybertruck How Silverado EV Stacks Up Vs Cybertruck, Rivian, Hummer, And Lightning 2022-rivian-r1t-rear
The base Ford Lightning offers two battery capacities. The company confirms a usable capacity of 98.0-kWh in the base model and 131.0-kWh in the upper trim, with estimates putting the gross capacity at 110.0-kWh for the base trim, and 145.0-kWh for the extended-range model. The Rivian R1T, meanwhile, packs a gross capacity of 135.0-kWh, while the Cybertruck is rumored to offer up to 250.0-kWh – which would make it the largest of the group.
If the Cybertruck does make it to market with that massive battery pack equipped, it would have the best range of the bunch; Tesla says it could drive up to 500 miles (805 kilometers) on a single charge with the quad-motor setup equipped. The Silverado EV would be the next-best with 400 miles (644 km) of range. But when it comes to electric trucks currently on sale, the GMC Hummer EV is the range king with 329 miles (530 km) on a single charge, followed by the Rivian R1T with 314 miles (505 km), and the Ford Lightning with up to 300 miles (483 km) of range.
Max CapacityMax Range
Chevrolet Silverado EV200.0-kWh (est.)400 Miles (est.)
Ford F-150 Lightning110.0 / 145.0-kWh230 / 300 Miles
GMC Hummer EV200.0-kWh329 Miles
Rivian R1T135.0-kWh314 Miles
Tesla Cybertruck250.0-kWh (est.)500 Miles (est.)
Charging
The new Silverado EV (in RST form) and the Hummer EV offer the fastest charging rates of any other electric truck – and most other EVs for that matter – up to 350 kilowatts. That means these two pickups will be able to recoup 100 miles of range in just 10 minutes at a compatible DC fast charging station.
Next-best is the Rivian, which achieves rates up to 210 kilowatts and can recoup 140 miles in 20 minutes. The Ford Lightning is behind the eight ball comparatively, charging at a maximum rate of 150 kilowatts, and juicing from 15 to 80 percent charge in 41 minutes.
Tesla Cybertruck How Silverado EV Stacks Up Vs Cybertruck, Rivian, Hummer, And Lightning ford-f-150-lightning-pro-2022
Tesla Cybertruck How Silverado EV Stacks Up Vs Cybertruck, Rivian, Hummer, And Lightning tesla-cybertruck
Tesla says that the quad-motor Cybertruck (formerly the tri-motor model) will be able to charge at a rate of up to 250 kilowatts, which would put it above the Ford and Rivian, but still below the Silverado and Hummer. Hopefully Tesla releases more specifics ahead of the truck's debut, which is scheduled for this year.
Max Charging Rate
Chevrolet Silverado EV350 Kilowatts
Ford F-150 Lightning150 Kilowatts
GMC Hummer EV350 Kilowatts
Rivian R1T210 Kilowatts
Tesla Cybertruck250 Kilowatts (est.)
Power
Range and battery capacity are definitely huge factors when considering an electric truck, but for a lot of people, power still plays a role. The good news is that all of these trucks pack plenty of it.
Tesla claimed 800 horsepower (597 kilowatts) and a 0-60 time of 2.9 seconds in the Cybertruck tri-motor model. But with news of the new quad-motor model, those figures could be even better. As far as production trucks go, the GMC Hummer EV is the fastest and most powerful, with up to 1,000 hp (736 kW) on tap and the ability to hit 60 miles per hour in just 3.0 seconds via its "Watts To Freedom" – or WTF – launch control system.
Tesla Cybertruck How Silverado EV Stacks Up Vs Cybertruck, Rivian, Hummer, And Lightning 2022-gmc-hummer-ev
Tesla Cybertruck How Silverado EV Stacks Up Vs Cybertruck, Rivian, Hummer, And Lightning 2024-chevrolet-silverado-ev-rst-rear-view
Just behind the Hummer is the Rivian R1T, with an impressive 835 horsepower (614 kW) and the ability to hit 60 in just 3.5 seconds. The Ford Lightning, meanwhile, offers 426 hp (313 kW) in the base model and up to 563 hp (414 kW), with a 0-60 time of 4.5 seconds. And when the Silverado EV officially goes on sale in a few years, Chevy says it will have 664 hp (488 kW) and a 0-60 time of 4.5 seconds using the Wide Open Watts (WOW) launch control model – but the base model will be far less powerful.
Power0-60
Chevrolet Silverado EV664 HP / NA4.5 Seconds (est.)
Ford F-150 Lightning426 HP, 563 HP / 775 LB-FT4.5 Seconds
GMC Hummer EV (Edition 1)1,000 HP / 1,200 LB-FT3.0 Seconds
Rivian R1T835 HP / 908 LB-FT3.5 Seconds
Tesla Cybertruck800 HP / 1,000 LB-FT (est.)2.9 Seconds (est.)
Towing & Payload
These are still trucks, after all, so they need to do truck things. Towing and payload capacity are still two of the biggest factors buyers consider when looking for a new pickup.
Believe it or not, the Rivian R1T is the top towing truck of the group of production models, able to tug 11,000 pounds (4,990 kilograms) with the quad-motor option equipped. The payload figure is impressive too, second-best in the segment at a hearty 1,760 pounds (798 kg).
The Ford F-150 Lightning and Chevrolet Silverado EV can both pull up to 10,000 pounds (4,536 kg) in the right spec – and Chevy even promises a later HD version that can move 20,000 pounds (9,072 kg). The Lightning wins the payload award, though, with the ability to haul up to 2,000 pounds (907 kg) with the smaller battery pack, while the Silverado and Hummer fall just short of that figure with a max payload capacity of 1,300 pounds (590 kg). And the Hummer only tows 7,500 pounds (3,402 kg) by comparison.
Tesla, though, says that the Cybertruck will beat all of them when it goes on sale. The quad-motor model will reportedly be able to tow at least 14,000 pounds (6,350 kg) and haul up to 3,500 pounds (1,588 kg).
Max TowingMax Payload
Chevrolet Silverado EV10,000 Pounds (est.)1,300 Pounds (est.)
Ford F-150 Lightning10,000 Pounds2,000 Pounds
GMC Hummer EV (Edition 1)7,500 Pounds1,300 Pounds
Rivian R1T11,000 Pounds1,760 Pounds
Tesla Cybertruck14,000 Pounds (est.)3,500 Pounds (est.)
Update (1/07/2021): Pricing for the base GMC Hummer EV has been added, and the torque and capacity figures have been updated to reflect the Edition 1 model.
FutureBoy
FutureBoy
Reginald
Kirkland WA USA
Toyota Sienna
Financial Advisor
This is a pretty nice although overly simplified comparison. They do sound pretty skeptical about the CT stats though. And the stats used are of course those of the CT3 because the CT4 stats are not yet released. If they are skeptical now, they might just have their minds blown with CT4 stats.
One thing about the comparison, I'd like to see the new CT specs up the max charging rate to match or beat the others. This is an EV-specific stat and if the Hummer and Silverado charge faster than CT, you can bet that there will be no end to their bragging about it. Plus, faster charging is always a good thing (unless it causes vehicle fires or battery degradation of course).
Another curious point is how CT is listed as having 0-69 at 2.9 seconds. But the Hummer is just under that at 3.0 seconds but has to do it using launch mode with a long warmup period. Silverado also comes with this time-consuming launch mode. Seems like such a gimmick if you need to sit there for a while and warm up the vehicle before you can launch. I don't know if CT will have this same wait period but I don't remember seeing any other Tesla's that need to sit and wait for a while before launching.
I think the way they measure charging speed isn’t very good.
Max charge rate isn’t very useful if your vehicle tapers off from that rate after 30% charge.
It also doesn’t take into account efficiency. If your vehicle will charge faster.
Probably the most relevant charging speed measure is how long it takes to add 200 miles range starting from 10%. Or maybe both adding 100 miles and 200 miles from 10%.
This is the most straightforward comparison I've seen yet. No FUD, just a newest information to date. Refreshing.
It is pretty decent.
Particularly considering half the vehicles are either not released.
jerhenderson
Jeremy
Prince George BC
Correctional Officer
By: Jeff Perez
Price
Base Price
Rivian R1T$67,500
Capacity & Range
Charging
Max Charging Rate
Power
Power0-60
Towing & Payload
oh please... everything about the Silverado is concept - no data provided in this thread about it is based on facts.
Quicksilver
Charles
Alabama
Nissan van
Retired military
Until any of these vehicles are ramped up to full production scale (including the CT) we are still just speculating on who leads the pack.
Of all the start ups and legacy automakers Tesla will ramp up faster because they have it down to a science.
My personal opinion is that at least two legacy companies and a couple of the start ups will not make the cut.
The Chinese will be a force to be reckoned with if they produce exportable trucks at volume.
As Elon has stated many times concept and design is easy, production it the hard part.
Any company that doesn't have the cash to burn while they ramp up is headed to bankruptcy.
The legacy companies have the additional handicap of still making a profit on ICE vehicles while losing money on every EV they sell.
Eventually they reach a tipping point where they are not making money on either while still having huge debt and overhead.
At that point we will either see a government bail out of one or more of them or they will bankrupt and reorganize to strictly make EV's if they have achieved the ability to do so at scale.
Shareholders, workers and taxpayers will be the losers when that happens.
It is going to be a very interesting next few years.
If you haven't checked out this guy watch a few of his videos. He doesn't pull punches and you will either love him or hate him.
Same could be said of the Cybertruck.
In any case, the Silverado is just an EVilanche skin on the Hummer so we know roughly what it’s going to be like.
jerhenderson
Jeremy
Prince George BC
As we are facing potential model changes now, I can agree to a point, but we know how Teslas perform based on other models whereas the Silverado has no prior data to draw from.
Likewise, we have performance data on the Hummer which is extremely close to the Silverado.
The big wild-card on the Silverado is going to be range. I kind of doubt they will get that 400 mile range, the Hummer was supposed to have 350 miles and it dropped to 329 or something. I suspect the Silverado will similarly drop prior to launch.
DrShah
Samir
Davie, FL
Tesla Model Y LR
Surgeon
Performance specs are one thing but I really hope Tesla adds an OEM powered frunk, air conditioned ventilated seats, and the ability to power your home during an outage ( just like the Lightning F150 & Silverado EV). Man I can't wait till they start making this beast!
uff_da
North Dakota
I agree- I wish there was a standard format for the entire charge curve that has to be published. It is really sort of an "area under the curve" type of metric. This is also why a giant 500 mile range CT sounds so appealing. You can go from say 100 miles to 300 miles of range while staying in that high charge rate portion of the curve for hopping from supercharger to supercharger without having get into the slowest portions of the curve.
