how to remove or adjust the band above the windows
Bumn
Laurence
Boca Raton
sorry not sure of proper part name, but I have one tight space on passenger side by windshield but where it ends at passenger rear door a big gap and I believe that is loose and making a banging noise when hitting bumps, the other side both front seam and rear seam gaps are equal in size... I want to remove or loosen to try to even out space and snug up bolts
UberNoob
CyberBeast & M3P
Desktop Security Engineer
If you’re taking about the stainless part that cooks like this ^ , it’s glued on I hear.
aeroguy
VA
Sounds like the cantrail. Attached by a bolt and ~13 clips. I had a bolt come loose then come off while off roading and replaced with a 6mm bolt. Sounds like you have a little more of an issue, but a picture would help.
https://service.tesla.com/docs/Cybe...UID-7B9154B0-0197-413A-899A-0FF3FA01B788.html
Bumn
Laurence
Boca Raton
