New Battery Range & Pack Architecture [Announced at Battery Day]
Hoppi
Reginald
Kirkland, WA
cybertruck tri-motor
So with the new Battery Day announcements, it sounded like the new batteries would get something like 56% better range... So does that give the CT tri-motor a 750+ mile range?
Looks like the CT gets the same kind of batteries as the Semi with the Full Nickle cathode which Elon mentioned was really important for the best possible range.
Advertisement
Newton
Newton
East Bay Area, CA
p̶r̶i̶u̶s̶ c̶,̶ y̶o̶t̶a̶ p̶i̶c̶k̶u̶p, ⼕丫⻏🝗尺セ尺ㄩ⼕长
Im about 90% sure the quoted ranges were with this new batterie tech in effect. but I also think they will increase the range by 50 miles for each truck.
so base single will have 300, double 350, triple 550? if im remebering the quoted ranges correctly
Dids
Les
Massachusetts
04 Tacoma, 21 Cybertruck
Self
Why do you want 750 miles from a single charge? No one drives that far without stopping. Wouldn't it be better to have a 500 mile pack that charges in 10 min?
Dave.Me
Dave
Winnipeg, Manitoba, Canada
2010 GMC Sierra Z71 - Cybertruck Dual Motor ordered - 2018 Subaru Forrester
Retired - CNR Signals & Communications Technician
When it's -30c below you'll loose 40 to 50% of your capacity is why.
Hoppi
Hoppi
Reginald
Kirkland, WA
I'm not saying that I need 750. And from what I saw of the presentation, there wasn't any announcement about charge speeds. I'd be psyched if charge speed went to 10 minutes. Even if you just get to 80% charge in 10 mins I'd be happy. But it would be sweet if we get 80% charge of the 750 miles in 10 minutes.
larryboy31
larry
springfield NE
2001 Dodge turbo diesel ext. cab,2016 Nissan versa, 2021 Subaru cross trek
Was any reason mentioned as to why the 2 motor CT could not have the 550 mile battery?
Newton
Newton
East Bay Area, CA
alot of people are wanting this, but They only gave those 3 specs on CT reveal day. and this early (over a year and a half before production) i doubt they have anything finalized
I think they need to make the double motor higher range too
Turtle
Roger
South Carolina
Cyber Truck
I would expect approx. 770miles of range in two years! This would be huge for all range is king people. That doesn’t mean you can actually drive 770 miles on a charge, but you could possibly get 470 miles which would be approx. the 60 percent range for normal every day driving. For traveling, towing or camping you would be able to use the full range as necessary. This will be very necessary for those of us that would be using the power outlets for charging the Cyber Quad, power tools and other items that need power! YES, we need the range!
Dids
Les
Massachusetts
Self
They did kinda, Elon fumbled about saying the elctrons don't need to travel to the tab and that is somewhat equivalent to saying reduced internal resistance. That means faster charging + more efficient charging.
CappyJax
Bakersfield, Ca
Subaru Forester
Pilot
It is just a bigger Cell. It makes it cheaper to produce. At the pack level, there might be some increase in energy density, but it isn’t 56%.
Newton
Newton
East Bay Area, CA
It's not just a bigger cell. It's almost completely reengineered
fritter63
Atascadero
Software Engineer
Why do you think it wouldn’t scale for the same size pack?
Advertisement
Advertisement
