Onboard air compressor never shuts off.
Jacob
Jacob
Michigan
69 BB Vette, 83 Cutlass
It seems that if my air compressor for the suspension kicks on it will NEVER shut off until I put the truck in park. I can hear it running all of the way to my destination and occasionally hear it bleed off (what I'm assuming is excess air pressure) multiple times on my way but it will continue to run. Anybody else notice this?
Cybertruck26
Chris 🇺🇸 🇮🇪 🇨🇦
Bay Area, CA
Cyberbeast (07/2024 delivery)
Veteran, Engineer, Space 🤓
Hmm, how often do you get a message saying it's unavailable due to not being in operational temps? I didn't realize that I had a few locations saved for heights, so on my way home from work it would adjust to the highest setting at least 3 or 4 times. I wish you didn't have to be at the location to remove the location based height adjustment.
Jacob
Jacob
Jacob
Michigan
I've never gotten the "over temp" warning that I'm aware of. I always just try and get home quickly so it'll shut off. It only takes like 15 to 20 minutes for me to get home but it runs the entire time, purging air occasionally going, "pfffshshshshsht, pfffshshshshsht".
Jacob
Jacob
Jacob
Michigan
OK, update. This is not consistent. It was working fine for me the other day and shut off. Still seemed to run for a long time though before it did.
Fausto
D
Model S LR
I have a similar thread about this. Runs for a long time when using higher mode in dynamics
Stuck4ger
Cape Canaveral, FL
Aerospace
If you use a manual height mode it always pumps it up when slow or stopped and bleeds it off as you go far enough or faster. I always hear mine lower passing around 50mph. You can swipe the info display left to cycle from whatever music is playing to a trip odometer and then to ride height and watch it change.
You can delete all saved locations for height on one of the display pages (I can’t find it in the owners manual and am on a trip without my truck so I can’t tell you more)
