- Florent
- Mar 12, 2025
- CA
- Cybertruck
- #1
Hey everyone,
We've all been there – needing to air up tires, inflate camping gear, or even power air tools. When it comes to air pumps, there are two main camps: the portable crew and the fixed (on-board) enthusiasts. Both have their loyal followers, and for good reason! But which one truly reigns supreme in terms of convenience, performance, and overall utility?
Let's break down some of the common arguments for each, and then we want to hear from you!
Which Team Are You On?
Are you a proponent of the grab-and-go portable air pump, valuing its flexibility and cost-effectiveness? Or do you lean towards the always-ready, high-performance fixed system, appreciating its seamless integration and power?
Looking for The Best Air Compressor in 2026?
Wolfbox HyperFlow X on-board air compressor tested by our group member, proven to be robust product with high-performance.
Original post of test 1: https://www.facebook.com/share/p/1A36SVc4gE/
Hard Wire Connection
· The famous one: Hardwired with 2GA Copper wire from Battery to back of Bronco and mounted.
· Wolfbox Hyperflow X: Temporary connection using Jumper Cable to Battery from Positive and Jumper Cable to Ground from Negative
Hose Connection: Bulldog 4 hose inflation system used on both.
· The famous one: Connected to installed air chuck on bumper which has 4 feet of 3/8” Stainless Steel braided hose between compressor and chuck on bumper
· Wolfbox Hyperflow X: Inflation system connected directly to compressor chuck
Actual Inflation Time for all 4 tires: Ford Bronco – BFG KO2 35” Tires. Inflation from 19lbs to 40lbs
· The famous one Time: 6:45:12
· Wolfbox Hyperflow X Time: 5:15.69
Sound – The Wolfbox seems to be quieter, however, I will not really know until it is installed inside the rig.
Original post of test 2: https://www.facebook.com/share/p/1Dfx1QozoQ/
RESULTS - 4 tires using 4 hose system...
The famous one Results
Air Up Time (NO TANK) - 6:45:12
Wolfbox Hyperflow X Results
Air up time (NO TANK) - 5:16:23
Air up time - (With 1 Gal Tank at 150PSI to start) - 4:37:15
Tell us in the comments:
- Which type of air pump do you use, and why?
- What are the biggest advantages and disadvantages you've experienced with your setup?
- Has a portable pump ever let you down in a critical moment, or has your fixed system saved the day?
- Any specific brands or models you swear by (or swear at)?
