power off button?
Bumn
Laurence
Boca Raton
what does the power off button do on the safety screen? is it like, a full power off ? do you use it to re-set all the computers in the truck? thanks
dalton108
Dalton
ā€˜24 FS/CB; ā€˜24 MX; ā€˜23 MS PLAID (Prior: ā€˜20-MY; ā€˜21-M3P) (Also: ā€˜14-FJ; ā€˜21-C8)
Lawyer
The power button is like your power button on your PC it just turns your truck off instead of putting it into sleep mode.
Soft reset is done by holding down the two scroll wheels for about five seconds until the truck restarts.
CG Cowboy
Dale
Lebanon, TN
www.cgcowboy.com
Cybertruck Foundation Series
I can tell you it saved my ass today. First road trip from Nashville to Chicago and received the critical error and to pull over immediately. Reduced power so I was essentially dead on the side of highway 65. I powered off then on and I was able to complete the trip. The route was still active in the navigator when I powered back on so clearly some things were saved into memory.
TorqMonstr
Scott
Beast, M3 MY
Mechanic
Fyi, many of the faults will clear after a power down (exit the vehicle and screen off) and on the next power up, if the condition isn't present.
Intermittent connectivity problems might resolve themselves temporarily. However, when a fault occurs and messaging advises on pulling over, once you shut down the vehicle may be disabled. So depending on the error message, you may want to elect to keep driving to a better location than the side of the road. my $0.02
TexasRaider
JR
Denton
Cybertruck + MS
Civil
Is anyone able to actually POWER OFF their CT?
When I select power off, the screen goes black but then turns back on and the vehicle reacts as it’s fully on. As in, I don’t believe the button works. (2024.45.32.15)
I had this, needed to do double scroll wheel reset first, then power off after the screen rebooted.
Pretty much anything, such as opening the door, will induce a power-on.
TexasRaider
JR
Denton
Cybertruck + MS
Civil
Update: Spoke In-person with the local shop, they said the CT basically won’t STAY powered off. It’ll go to ā€œsleepā€ and stay asleep until the user wakes it up/pings it within the app.
That works for me, as my experience with not driving the CT for a week or so while away for work - the drain of electrons are minimal as long as I don’t wake it up via the app.
Coolness!
When mine was being weird, it never fully shut down.
With recent software updates, it will go multiple days between top offs (3% triggers it, I think).
Redfire
Atlanta, ga
Cyber Beast
That's pretty much it. The truck will go to sleep as soon as you get out, but it won't fully power down for a couple of hours. That's just a way to force it.
However, all of these are kind of soft power offs. If you need to do a hard reset then you need to disconnect the MV power in the frunk.
