stumby
Josh
Philly
Model S P90D
1) Roof glass tint
2) Tires & wheels
3) Color vinyl wrap
Reactions: CTM
Muskwatcher
Martin
Arkansas
Silverado 1500 LTZ Crewcab, Toyota Avalon
Military
1. Vinyl wrap
2. Roof racks of some sort
3. Larger tires/lift kits(not sure how those would work on an EV)
DMC-81
Dana
Transformers Camaro SS, 1985 Corvette Z51, Dodge Magnum R/T, 1981 DeLorean, CT reservation
Not necessarily the top 3 among all buyers but, because my CT will sit outside in the Florida sun, these are the 3 modifications I'd be getting:
1) depending on Tesla window heat barrier solution, extra Ceramic tint and an interior removable roof glass visor/ cover
2) a quality outdoor car cover
3) depending on Tesla wheel options, an aftermarket wheel and tire package to achieve a look similar to this:
CyberRich
Rich
Tampa, FL
2019 M3 LR Grey, 2018 M3 LR Red, 2015 MS 70D Red
Car cover? What’s you rationale behind that choice, given that the truck‘s not painted?
Delusional
Phil
Pittsburgh
F-150
Construction
My initial reaction was....
1. Ladder Rack
2. Ladder Rack
3. Ladder Rack
After thinking about it, in order of popularity...
1. CyberQuad
2. Roof/Ladder Rack
3. Camper
Most likely, Tesla will have all three of these as factory options.
Don't forget a possible tesla trailer.
I really like the idea of a front push bar, often called a bully-bar or brush-bar. Those are relatively popular today. You need a place to mount your winch. However, the lack of a frame on this vehicle may complicate matters, you may have to reinforce the mounting points for a bullybar significantly.
Pretty much any welding done will mean TIG welding. It's something that humans have trouble with, you need a real pro to do TIG welding properly, but robots don't mind TIG at all.
Tacoma TRD Pro
  • Thread starter
  • Thread Starter
  • #10
Reflective film on the glass roof and front side window tint will probably be my only modifications. I like leaving my vehicles factory original and not modifying them.
Reactions: CTM
thejohnllama
Washington
2013 Nissan Leaf, 2007 Toyota Prius
Marketing Consultant
Preserve the rubber bumpers, tires and window rubber from damaging UV rays.
Totally agree that sunlight, moisture, and “the elements” wreck weatherstripping on most cars. Hopefully Tesla can do some material engineering to reduce/eliminate the effects
hridge2020
Henry
Central Coast CA
Tesla
  • Check quality/flaws full operation of controls
  • Soundproofing/insulation check/install
  • Interior lighting changes/(change the stock to brighter LEDS_
  • Window Tinting
  • Display Screen Protection
  • Enhanced floor mats
  • Caliper color change
  • Window Tint/shades as required
  • Bed setup for modifications T Slot / L Track
  • Towing setup
  • Audio/Camera setup/recording format
  • Enhance modifications designs
DMC-81
Dana
Just like Mini2nut said above. I plan to keep this vehicle a long time, and while the Central Florida weather is excellent to prevent rust on any other vehicle, the constant UV exposure will deteriorate everything else but the Stainless over time. I'm fortunate to get to park in a parking garage at work ( that includes free stalls for charging BEVs) so I normally cover my daily driver on the weekend and exercise my other 2 that are garaged.
Ehninger1212
Jake
Houston, TX
Architect/Fabricator
I just want my CyberTruck.. i cant even begin to think what i will do to it once i receive it! it all depends what its like in stock form.
for me most likely
1. Tire upgrade.. unless it can be ordered with all terrains.
2. nothing
3. nothing.
The truck is just so perfect in my opinion. I think wrap will be one of the top mods though, Wrapping this vehicle will be SOOOO easy.
Advertisement
Advertisement
