Size of garage for my Cybertruck
Skibumak
Anchorage,Ak
Toyota Tundra, Cybertruck in 2023
So if Elon says he needed to shrink the truck to fit into standard garage just how big of garage do I need?? I live in Alaska so parking outside is not an option really in the winter. So what are the dimensions of the garage to fit the truck i will need to have?
Advertisement
Roslyn
Roslyn
Kitwanga
Isuzu Tracker II 1988, Ford Explorer 1993
Anthropologist
What do you need a garage for ? Are you worried about rust ? Are you worried about hooligans damaging it ? That maybe your tush might not be warm enough ? What Are You Worried About ? Check out the videos of the Cybertruck driving in Alaska (yes), Norway, etc. As long as you have reasonable access to electricity, you should be just fine in cold weather. Just do the research. Several S3s in nearest small city (pop. ca. 70,000, w/chargers), and nothing but good reports. (This is from a little old lady (5'2", 70 yo) who's tired of nonsense vehicles, and looking forward to a vehicle to keep up with my northern British Columbia lifestyle.)
ev4me
Kevin
Winter Garden, FL
Cybertruck (single motor)
Construction Estimator
It's no fun removing snow around any vehicle, no matter if it's SS.
wiki dimensions: (I assume the 75" height is the max, before the self-leveling suspension is used)
Wheelbase149.9 in (3,807 mm)[6]
Length231.7 in (5,885 mm)[7]
Width~ 82.0 in (2,083 mm)
Height75 in (1,905 mm)
Skibumak
Anchorage,Ak
No my concern is not my tush but the optimization of the batteries being left in the cold and having to be heated 24 hours a day. Seems like unnecessary wear to me.
Roslyn
Roslyn
Kitwanga
Anthropologist
From Aron in Saskatchewan, in a thread on this site specifically asking about the Cybertruck in cold conditions: "All electric cars lose range with temperature but so do ICE cars. It is only temporary and will be better again when warm. Battery size and charge speed is the best way to overcome this issue. The bigger the battery the more capacity it has to run the thermal management and warm the batteries which lets you go further in the cold. Faster charging let’s you get back on the road faster and not cool down to much. Right now you will loose 1/4 to 1/3 range around -20C. The colder batteries are only one aspect of this reduced range. The denser air has a lot to do with it. My current ICE vehicle goes between 500-600km on a tank depending on wind in the summer. In the winter I get between 400-450km per tank. So an ICE vehicle loses 1/4-1/3 range in winter too. Drag coefficient and efficiency of electric are better than ICE cars so that helps. You can change your heating in an EV and get more range. I have a heated hoodie that I will use to help me get more range by reducing the heat output if I need. Can’t do that in an ICE vehicle."
Skibumak
Anchorage,Ak
I have been looking at either expanding my garage wider and longer or possibly getting a new house. Most of my life I have parked my trucks outside and plugged in when needed. I just wanted to be a little nicer to this truck if I could and also maybe give the battery warmers a rest sometimes. Sounds like I don’t need to worry about that. It’s funny most of the Tesla’s I have rent have been kept in a garage so having one just sitting out front seemed odd. Thanks for the input and I guess I have some measuring to do. 😁
mrbulk
Las Vegas
Tesla Model S75D
We're fortunate that in about two years we will move into our other place which has a 22-foot long garage; the one we are in now is only 20 ft long plus has a 2-foot thick row of cabinets built into the back wall so effectively only 18 feet of parking length, rather challenging to park the S that I am leasing now, even using the proximity sensors in front. So just in time for the CT...
Alan
Alan
Seattle
2017 S90D 2014Tacoma
You can set the car to finish charging before you leave. The battery warms up as it charges.
Akgolf
Jimmy
Jones, OK
2016 Nissan Leaf and 2016 Toyota Prius V.
Retired Computer Programmer, USAF
I Spent 28 years In Anchorage. Retired and moved south in 2016. I really miss the summers, but not so much the winters. I think the cybertruck will do well in Alaska.
VolklKatana
Aaron
Madison, WI
2013 Tesla Model S 85, '06 BMW Z4 Roadster 3.0si, Soon: Tri-Motor Cybertruck FSD
Database Administrator
with all the concerns about size, its within an inch or two of the dimensions of my 2014 Chevy siverado crew cab 1500. I have seen comparisons where fords are close as well, so basically, if a truck today will fit, so will the CT.
Skibumak
Anchorage,Ak
I agree, I have a Toyota Tundra Crew Max and height is 2" taller, 3" narrower and 4" shorter then Cybertruck. Problem I have is most new homes now a days have garages for cars not trucks. I guess I need to build a garage just for my trucks, problem solved! 😁
mrbulk
Las Vegas
Tesla Model S75D
I've seen some homes that had "tandem" garages, which is twice as long on one side, so even a CT w/trailer could fit. Would be cool if you could build one like that...(y)
Not really. Air at -20°C is only 16% denser than air at + 20 °C. Yes, that's significant but I wouldn't, given that drag is only one of several loads, say that's a lot. I'll suggest, based on observation, that stuff on the roadbed is the biggest factor. Even rain can increase the consumption of a BEV by 35 - 40% so I'm guessing that snow, sand etc. would have a similar or worse effect. Also keep in mind that the hypoid oil in the differentials is going to be thicker in cold weather, at least for the early part of a drive.
Heating usually gets the majority of the blame and some of that is deserved. But note that the Y has, and we can be sure that the CT's will too, a heat pump. This isn't going to do much at -10 °C and below but will do a lot to reduce the amount of battery energy required to heat at more modest temperatures. Also Tesla's are equipped with seat heaters. I didn't believe it until I tried it but you really can be comfortable at lower cabin temperature is your back an bum are warm.
Sirfun
Joe
Oxnard, California
Retired Sheet Metal Worker
As a golfer I can tell you in addition to the increase in friction of rain on the tires, rain has a huge effect on how far a golfball goes in the air. So you are talking about drag created by lower temperature, higher humidity and depending on how hard it's raining, water having a much higher density, causing a lot more aerodynamic drag. Of course I drive a golf ball a lot faster than I drive my vehicles.
Advertisement
Advertisement
