Snowplow mount / install on Cybertruck?
Scott2613
Scott
Waukesha, Wisconsin
22 S Plaid Track Pack 22 Model X 22 S Plaid 18 M3
Owner, Marshall Auto
Is there any provision for mounting/installing a snow plow?
Dazureus
US
'16 Model X, '21 Model Y
I know nothing about snow plows, but there's some provision for power in the front of the truck or in the frunk. Most likely for a 48V winch, but I wonder if the recovery points can be swapped out for the mounting blades of a plow. The only examples I've seen have the blades closer together and I don't know if that's something that varies from vehicle to vehicle, or if those mount points are custom installed, like an after market trailer hitch. If it can be a custom job, seems like the recovery points would be a solid place to mount something like that.
Scott2613
Scott2613
Scott
Waukesha, Wisconsin
T Sportline has a video of the truck on a lift. They did not remove the front aluminum skid plate and that's where the undercarraige would Likely mount. if possible. Also someone would have to make a 48V pump and lighting system. Someone mentioned that the Ford Lightning can't accept a plow either.
ldjessee
Lloyd
Indiana, USA
I definitely think that the recovery points could be leveraged to mount a snow plow and I think NowYouKnow YT channel discussed this.
I have also seen hitch mounted blades…
