Solar Flare
TruckDaddy
Tri-motor
If we ever had another "Carrington" level event or EMP attack, would the CT be more vulnerable than a regular vehicle? Is there any way to protect the electronics?
Dids
Les
Massachusetts
04 Tacoma, 23 Cybertruck
Self
Not more vulnerable... EMP and solar flare are not the same thing exactly... A nuclear EMP has several components that cause damage. The E1 pulse is caused by gamma radiation interacting with atmosphere and this causes a high electric charge in coupled electronics no matter the length of the conductor. This would fry a Cybertruck as well as any other vehicle. The other damage of EMP the E3 pulse is like a solar flare it is caused by distorting the earths magnetic field just like the solar flare does. This induces a high voltage in long conductors ( several kilometers). It is unlikely to cause any damage to Cybertruck... unless its charging then the high voltage probably would mean you need a new truck.
myco.rrhizae
Myco
N. Cal
F150 4.9L, Chevy Volt, Tri-Motor Cybertruck
Carpenter
awesome.
