Tesla Wall Connector for CyberTruck -- get Gen 3 now or wait for Gen 4?
Nidavellir
Pre-Order CyberTruck
I would like to get the input of members. I would like to get a Tesla Wall Connector Gen 3 installed. My question is, do you think it is ok to get the Tesla Wall Connector Gen 3 now for the CyberTruck or is it better to wait closer to launch to see if a Tesla Wall Connector Gen 4 is released?
CyberT
Orange County, CA
2018 Model 3 LR RWD
Service Technician
It depends if you are in a construction or remodeling phase now. If yes, then it makes sense to add the Wall Connector now.
If you are not then there is no hurry to add one now as we are around a year out from the CT production ramp where early reservation holders start getting their trucks. (yes I know that initial production will likely start this summer but it will be a slow ramp before any meaningful production is met)
Here are also a couple of qualifying questions for you.
1) How early of a reservation do you have?
2) Which version are you interested in buying?
Since we do not know for sure which version will be at launch, the version you are wanting could possibly be pushed out until later in 2024 or further beyond.
Nidavellir
1) I ordered the second reservations opened and my number is below the 700's
2) I will buy which ever version is released first
SolarWizard
MB
San Diego//Tampa//South Park, CO
3.0L JT // Quad CT
no point buying an outlet without knowing the max onboard charger capacity . We’re offering a unit now that can needs a 100A breaker and delivers 80A. Gen 3 is on a 60A delivering a max of 48A
if the onboard charger on the CT is still just 11kW that’s fine but otherwise you’re missing a lot of time savings
Nidavellir
What is the unit that needs 100A breaker and delivers 80A?
Is it the ClipperCreek CS-100?
BigAl
Al
CyberTruck
I asked this question a while back and was told the Gen 3 was the way to go... do you really think they will make a new version this soon? Maybe a year after release to see how things hold up to existing gear?!?
RandyS
Randy
If they make a new version of the Wall Connector, it may not be just because of the power output. It may also have additional features, such as Vehicle-to-Home or Vehicle-to-Grid connectivity and the associated safety / protection features. That may be worth waiting for, if you're interested in those features...
android04
Crete, NE
You can also buy a Gen 2 Tesla Wall Connector, since that supports 80A charging output (with a 100A breaker and circuit). Most Teslas can't make full use of that output and I think that's why Tesla didn't make the Gen 3 go that high, but there are a few older Model S and X with dual chargers that can make use of it. We don't know for sure yet, but perhaps the Cybertruck will also be able to charger at a higher rate.
Rutrow
Dan
Little Rock, Arkansas
Firefighter
I wouldn't run wires for anything yet. I'd suggest waiting until we find out the L2 charging specs for CyberTruck first.
SolarWizard
MB
3.0L JT // Quad CT
we’ve been installing BLINK chargers for a long time.
we are also in final testing for several brands, ( 100A and even 120A circuits) several I can’t name and some I can, like Charge Point or Sol-Ark They will be limited release in Q3 and wide release Q1 24.
thebenefits to going with a great non tesla brand like those above and several others .
One, having had dozens of brands opened up before, some are better built and/or easier /safer to wire correctly.
two, not being stuck in the ecosystem and charging friends non tesla vehicles
Three, if you want or eventually want to a 2nd, third or even fourth charger on the same circuit the top end amperage matters even more
me personally I’m hoping for dual onboard 11.7kW chargers. If thats the case, 120A circuit will be required to safely achieve the top speed, that would half the charging time vs the gen 3 wall connector.
Crimson_Fate
Scott
You can still install a GEN3 with the 60A but with wire gauge sufficient for 100A. This way you are all set with charging today and if you ever have the opportunity/need to upgrade you could just swap out the GEN3+60A for a another charger with up to 100A. Just make sure the electriction knows you intend to install a 100A in the future so they can upgrade your other wireing/service if needed.
CyberExperience
Bruce
Bluffton
flyingmpartners.com
Jeep Rubicon, Chevy, Porsche , BMW GS, SeaBreezeLX
Analyst
A 100amp charger must require some serious electrical panel upgrades. Not sure most homes have an extra 68/80/100 amps of excess capacity.
