TruckElectric
TruckElectric
Bryan
Dodge Ram diesel
I disagree with the statement "most of us don't need 700 mile range".
There are just too many scenarios to list to justify the need for a 700 mile range.
About Elon's statement about battery-powered aircraft........headline: "Elon to take on Boeing, Lockheed Martin and Airbus". 😁
Elon could also take on battery-powered locomotives and win! Tesla Locomotives......yep!😎
Hunter Sawyer
Hunter
Construction Worker
I can drop that 700 miles to 125 on a regular day. It's not just a EV issue but specific work(physics definition of work) still requires a set amount of energy. It will truly be the start of the New World when battery energy density is that of petroleum. Won't happen for years though.
TruckElectric
TruckElectric
Bryan
Dodge Ram diesel
That takes a lot of work, brother! Kudos to the working man!
Battery energy density won't ever have to be equal to petroleum because the laws of thermodynamics work against the ICE.
So to use a portion of the title of this thread...."is coming sooner than you think";)
MEDICALJMP
Jeff
Omaha, NE
Nurse
Toss a trailer on the CT and see who needs a 700 mile battery.
ldjessee
Lloyd
Indiana, USA
reservation for 2 motor Cybertruck, Nissan Leaf, Subau Outback, Kawasaki Vulcan 1700 Vaquero ABS
programmer
How many ICE sold vehicles have a range of 700 miles?
The larger diesel trucks with extra gas tanks... but how many other vehicles?
I think this kind of thinking is what is keeping many people from switching to EVs.
TruckElectric
TruckElectric
Bryan
Dodge Ram diesel
Apples and oranges argument really.
When talking about range it's different with ICE. It doesn't take long to fill up an ICE and fuel stations are rarely a problem. So range is never the problem.
With an EV available charging stations are the problem mostly since the charging time is becoming less of an issue.
It's mostly about travel with EV's and not daily commutes back and forth to work. For some people range is not an issue but it seems those same people want to fit their situation for all or most people. Since they don't need it then it should not ever be considered as a problem.
Not if you think of it from from a different point of view.
ldjessee
Lloyd
Indiana, USA
programmer
Most people never use their car for anything other than commuting. I was shocked that having driven to 3 of the 4 corners of the contiguous 48 states how many of my coworkers had not driven out of the state or beyond the surrounding states.
I also consider the environmental impact of ICE vehicles. Getting rid of ICE vehicles is not a thing to do because it is the latest tech, it is because the ICE vehicles pollute more than EVs.
rharl
Robert
Greenville
cyber truck tri motor
insurance
I am looking a this as more towing that actual miles. 700 milers of range i don't really need but 300 miles towing a boat or other trailer i do need. It is capacity not range we need in n reality. A 700 mile range means more tow capasitiy.
TruckElectric
TruckElectric
Bryan
Dodge Ram diesel
It should be noted in this discussion about the car vs truck thing. Since I live in Texas that is my reference. If you have a car for commuting and then whatever else(general errands) then the issue of range is not an issue because you will not use a car(generally) for much else. Most people here in Texas that own homes(Apt. dwellers probably mostly own 1 car)have at least 2 vehicles and one is a truck. So the car gets used for commutes and the truck for both(2 drivers) commutes and general usage of trucks(hauling things).
So it gets complicated going over what gets used for commuting(car, truck or both) depending on how many is in the household. You get the idea.
To sum it up it's not a one-size-fits-all issue.
There is no disagreement on the pollution part, it's a no brainer.
Most aren't towing trailers.
So, point supported. Most don't need a 700 mile battery.
Many have more than one vehicle. So many could have one long and one short range. So most still don't need a 700mile battery.
(in our area we have 'mountain trucks' these barely if at all road-legal things just enough to carry stuff up the hill, not reliable enough to go far)
Not that we shouldn't have the option, but we also need cheap 100-mile vehicles out there. Most can't afford 40k vehicles.
outdoors_jp
Josh
Coeur d'Alene, ID
Highlander, Expedition EL, Cybertruck
Geologist
From my perspective with this kind of range I would never hesitate towing anything for the few times a year that I do. For the normal day use a larger battery means fewer cycle times. Fewer cycle times means longer lasting. right?
TruckElectric
TruckElectric
Bryan
Dodge Ram diesel
With the Million Mile Battery cycle times will not be an issue(you will never drive a million miles, most likely). But when you are hauling something(or not) while traveling it could mean less time at charging stations since you probably won't be needing as much of a charge between charging stations.
Lexus Rx450H Tesla Model 3
Researcher
The thing is, when an ICE car advertises a range you don’t really get 60% of that to maximize lifetime of the engine. 60% of 700 is 420 miles. That is a good number for a road trip, depending on how quickly you and recharge it. SF to Denver in 2 charges or start with a full charge and take it down to 20% at 560 miles and 1 more charge to 80% takes you in. So I’d be super happy if they had a 700-mile battery (no load) because then with a real load maybe you could get 200+ miles.
Advertisement
TSLA Stock
Advertisement
