TFL Truck F-150 lightning Ike gauntlet
Zabhawkin
New Mexico
A few things to note, the F-150 is compared to a Cummings powered Dodge 2500, so its punching well above its weight class.
Sirfun
Joe
Oxnard, California
Retired Sheet Metal Worker
I thought TFL said they used 1% of battery per mile in the regular towing test. I thought they said it may have a range of 100 miles for 100% of battery. In this uphill test, they drove 8 miles up a 7% grade and the state of charge went from 69% to 53%. Which would work out to 16% of charge to go 8 miles, or 2% per mile.
Yeah, going uphill pulling a huge box uses alot of energy. This isn't surprising. Especially at those speeds.
Drop the speed to 60, or 50 and the power use would drop by a third or more.
I see this all the time on my bike. I take the freeway, I can consume up to 3% per mile at 70. On a good day, though, I'll only consume 1% per mile at 35. If I tuck, I get about 5 mph for the same power.
The same is true about towing. You're dragging a big box through the wind.
charliemagpie
Charlie
CybrBEAST
In AU the national highway speed limit is 100k or 62 miles. There are also areas where 110k is allowed 69 miles. But it's mainly 100k.
Usually all 2 or 3 lane, so if you are slower, there is plenty of room for people to pass.
In particular, if you are towing an RV, God knows why you want to travel on the limit. You likely have your family in the car, slow down. You can lose much more than a sliver of time.
If I can save 30% for driving at 80k , 50 miles ? What a bonus. For me, range issue is now a non issue.
All this fuss. 30% extra for such a little thing.
Zabhawkin
Zabhawkin
New Mexico
Yep mis-converted the energy usage. Ill correct the main post.
Delusional
Phil
Pittsburgh
F-150
Construction
You are telling only half the story.
In 98 percent of cases, after driving uphill for a distance, you are going to get some downhill regenerative power restored to your battery.
I imagine towing a trailer downhill will add a lot more than the usual regenerated power.
Zabhawkin
Zabhawkin
New Mexico
They went down first, reported how much regen and how many times they applied the brakes, then drove back up.
towing range is going to be wildly dependent on speed choices
just today from a fellow F150L owner
“3000lb Camper, with the Lightning PRO... and while powering the camper from the truck, with ProPower, to the Far NORTH GEORGIA mountains. The elevation change was 1,500 feet higher from start to finish….
1.3 miles per KWH for the majority of the trip, somewhat hilly in many areas, which equates to about 127 maximum towing miles... to 0% state of charge.
1.2 miles per KWH for the last 50 miles mostly due to some stringent 'top of Georgia' elevation changes, from 1,200 to over 2,000 feet...
average speed, maybe 55-60, mostly 4-lane roads/highways
temps - low 70's to start, mid to high 80's in the later parts of the day
winds - none to light
accessories: music, always.... air conditioner, maybe 1/3 of the trip, and a small amount of phone charging.
ProPower powered the camper the whole trip, with an extension cord from one of the 20amp bed outlets. Running an RV absorption Fridge, a mini compressor fridge, and three fans, the draw was about 280w constant, and up to 350w for several minutes each time the compressor fridge kicked on.”
