Top Secret Video from Cybertruck Guy
Sirfun
Joe
Oxnard, California
Retired Sheet Metal Worker
Todd the Cybertruck Guy released a video 5 days ago that never made the rounds here on our forum. It's all about the information on the batteries from Rueters News service. Good enlightening information. Here's a link:
Advertisement
Jose mario
Jose
Bakersfield
CyberTruck
It's not exactly news that Jeff Dahn now belongs to Tesla. It's also not exactly news that his specialty is in finding electrolyte additives that prevent irreversible reactions between lithium ions and the SEI. It is thus not news that we can expect batteries which will do more C's roundtrip energy before a specific level of degradation is reached,
'Million Mile Battery" is marketing BS. But wer'e stuck with it now and will never get information that is meaningful.
Tacoma TRD Pro + Tesla Model Y
I agree, it’s all marketing hype. Same with “30X“ stainless steel that will be used in the CT.
Well we at least know what "30X" means as Musk specifically and clearly used the phrase "300 series stainless" in reference to it in the recent Leno video. I think this is what most of us had surmised but it's now confirmed.
I think “30“ refers to 300 series stainless steel and the “X” refers to Space X‘s proprietary SS alloy that was developed in house.
hridge2020
Henry
Central Coast CA
Tesla
Here's some 300 Series Stainless Steel Help
Stainless Steel 300 Series Austenitic Grades
This table is intended for reference use and not for design purposes.
ALLOY/UNSDESCRIPTIONC MAXNICRMNOTHERDENSITY
301
S30100
Chromium nickel steel capable of attaining high tensile strength and ductility by moderate or severe cold working..156.0-8.016.0-18.02.0 MaxP .045 MaxS .03 Max
Si 1.0 Max
.29
301LN
S30153
301LN is a higher nitrogen content version of 301L to compensate for the lower carbon..036.0-8.016.5-18.52.0 MaxP .045 Max
S .03 Max
S 1.0 Max
.29
302
S30200
General purpose chromium nickel stainless steel. Its corrosion resistance is superior to that of Type 301. It can be cold worked to high tensile..158.0-10.017.0-19.02.0 MaxP .045 Max
S .03 Max
Si 1.0 Max
.29
303
S30300
Free machining grade (sulfur added) with good machinability, corrosion resistance and strength..158.0-10.017.0-19.02.0 MaxP .20 MaxSi 1.0 Max
S .15 Min
.282
304
S30400
Low carbon chromium nickel stainless and heat resisting steel somewhat superior to Type 302 in corrosion resistance..088.0-10.518.0-20.02.0 MaxP .045 Max
S .03 Max
Si 1.0 Max
.29
304H
S30409
Controlled carbon grade of 304 for increased strength at operating temperatures above 800 degrees Fahrenheit..04-1.08.0-10.518.0-20.02.0 MaxP .04 Max
Si 1.0 Max
S .03 Max
.285
304L
S30403
Very low carbon chromium nickel steel with general corrosion resistance similar to Type 304 but with superior resistance to intergranular corrosion following welding or stress relieving..038.0-12.018.0-20.02.0 MaxP .045 Max
S .03 Max
Si 1.0 Max
.29
309
S30900
High corrosion-resistant, chromium nickel grade with carbon limited to .08.0812.0-15.022.0-24.02.0 MaxP .045 Max
S .03 Max
Si 1.0 Max
.29
309S
S30908
Controlled carbon version of 309. 309S maintains corrosion resistance at higher operating temperatures..0812.0-15.022.0-24.02.0 MaxP .045 Max
Si 1.0 Max
S .03 Max
.29
310
S31000
Similar to 309 with higher resistance to corrosion and oxidation at elevated temperatures..2519.0-22.024.0-26.02.0 MaxP .045 MaxS .03 Max
Si 1.50 Max
.29
310S
S31008
Maintains good strength and corrosion resistance at higher operating temperatures..0819.0-2224.00-26.002.0 MaxP .045 Max
S .030 Max
Si 1.50 Max
.29
316
S31600
Chromium nickel stainless and heat resisting steel with superior corrosion resistance to other chromium nickel steels when exposed to many types of chemical corrodents; superior creep strength at elevated temperatures..0810.0-14.016.0-18.02.0 MaxP .045 Max
S .03 Max
Si 1.0 Max
Mo 2.0-3.0
.29
316L
S31603
Low carbon chromium nickel stainless steel with general corrosion resistance similar to Type 316 but with superior resistance to intergranular corrosion following welding or relieving. It is recommended for use in parts which are fabricated by welding and cannot be subsequently annealed..0310.0-14.016.0-18.02.0 MaxP .045 Max
S .03 Max
Si 1.0 Max
Mo 2.0-3.0
.29
321
S32100
Chromium nickel steel containing titanium. Recommended for parts fabricated by welding which cannot be subsequently annealed. Also recommended for parts to be used at temperatures between 800°F and 1850°F..089.0-12.017.0-19.02.0 MaxP .045 Max
S .03 Max
Si 1.0 Max
Ti 5xC Min
.29
254 SMO
S31254
Highly resistant to crevice corrosion, pitting and chloride stress. Used in chemical, salt water, scrubbers and pulp/paper industry..02017.5-18.519.5-20.51.0 MaxP .030 Max
S .010 Max
Cu .50-1.0
N .18-.22
.287
Sputter
Herbert
Rockville, Maryland
2019 Model 3
I like your video. Seems logical to me. Check out my avator....yeah...I'd like to see your video on your off-road adventure. Last summer, I did the Trans Labrador Highway.
Mao Torres-Madrid
Mauricio
Bogota, Colombia
Bicycle, Model Y (2021), Cybertruck (when available);
Amway Business Owner
Great video and relevant info. would love to see your motorcycle trips.
shocker
Michigan
Bolt, Silverado,
Retired scientist
Re: grades of stainless steel. 301 or 302 would be logical choice for CT except Tesla is unique among automakers in doing it's own metallurgy. No surprise if 30X is the proprietary alloy from Space X - the more you buy, the cheaper it gets till the magic X ingredient runs out.
VI Tesla
David
Nanaimo
Model 3, Cybertruck
Also SpaceX is not using one type of 300 series. Just the other day they brought on some 304L stainless to bocca chica that had not been observed previously. My theory is that they haven't settled on the specific 300 series stainless yet for the cybertruck so the 'X' is just a place saver until they decide.
Doesn't mean they could come up with their own recipe as well. Musk has said that given the time since stainless development he doesn't see why with today's tech we shouldn't be able to come up with something new. That said, I bet they stick with a current blend fr Cybertruck as performance and tooling already exist.
Owner13669
Steven
NNY
Chevy Bolt
I’d bet on them using whatever the starship uses. Quantity discounts.
ldjessee
Lloyd
Indiana, USA
reservation for 2 motor Cybertruck, Nissan Leaf, Subau Outback, Kawasaki Vulcan 1700 Vaquero ABS
programmer
So many of these things have come true or been announced.
Advertisement
Advertisement
