Upgraded MF200 Is Up! Find The Biggest Change? $40 Discount Here
Wolfbox
Florent
Something powerful is coming.You’ll hear it before you see it.The beast just got an upgrade.😏 #.webp
My dear firends, please allow me to introduce our latest product, MF200.
We made some improvements. Please see them below:
  • Wind speed 66% up
  • Air pressure 100% up
  • Low speed - 30000 RPM
  • Medium speed - 60000 RPM
  • High speed - 110000 RPM!
  • Only 0.84 lb
What it can do?
  • Blow off dust and leaves✅
  • Drive away droplets✅
  • Raise camping fire✅
  • Air up the infaltables✅
  • Clean the interior space of your car, appliances and electronic devices...✅
Something powerful is coming.You’ll hear it before you see it.The beast just got an upgrade.😏...webp
Now we are offering up to $40 discount. Check it out now! Let's keep things tidy and clean!
Wolfbox
Wolfbox
Florent
I have your older Mf200. Great device. Does each battery have its own usb-c for charging or is there some different charging input? Can they be charged both in and out of the device? Can the device run off the battery while it’s in the device and plugged in?
How quickly does the battery charge? I see you provide a usb-a to usb-c cable so max 5w?
Mine gets rather hot after fairly brief use. How long can it safely run continuously with the swappable batteries?
Wolfbox
Wolfbox
Florent
Thanks for your questions.
Each battery has a separate charging port.
You can charge individual batteries or charge them while installed in the device.
Charging takes approximately 2.5 hours.
Each battery supports max 105 mins or so at the lowest mode.
