Nidavellir
- #1
If the Cybertruck comes with 35" tires and you replace them with 37" tires, will the speedometer and range correct itself?
As far as I know it would be off by 1 mph or 2. Don't believe the software accounts for tire size change.If the Cybertruck comes with 35" tires and you replace them with 37" tires, will the speedometer and range correct itself?
donāt forget all the sensors for autopilot FSD etcIf the Cybertruck comes with 35" tires and you replace them with 37" tires, will the speedometer and range correct itself?
sorry Iām confused those are wheel size selections, no?I imagine it will be similar to the current tire size selection available in the cars
Yeah, that's true. They're the sizes offered by Tesla.sorry Iām confused those are wheel size selections, no?
Wasn't the OP asking if the vehicle auto-adjusted for size?sorry Iām confused those are wheel size selections, no?
I may just be missing the pointWasn't the OP asking if the vehicle auto-adjusted for size?
So isn't that dialog clear that Tesla needs you to manually pick a diff size so it can recalculate?
Obviously there is a looks (rim style) aspect for the UI graphics but it seems the size is key too.
Aside: In fact it changed recently where that dialog would reboot more subsystems than a two-finger reboot and it was a work around in some case. Now that dialog is a few seconds vs a minute.
Yeah, that sounds like the senser pairing pop-up. It requires you to drive around a bit for it to popup.Come to think of it, I think it must be detecting the new tire pressure sensors!
It's not like those different wheel/tire configurations all magically have the same outer diamater though? the car's already compensating based on your selection. I thought that was the OP's question.I may just be missing the point
but OP asked about about changing tires from 35ā to 37ā
essentially irrelevant to whatās shown on the Tesla, changing wheel size
if the point is merely that āif Tesla can give options for changes in wheel size, they could also give options for changing tire sizeā then .. ok
admit I donāt know the detail assumptions behind the Tesla UI youāre showing.It's not like those different wheel/tire configurations all magically have the same outer diamater though? the car's already compensating based on your selection. I thought that was the OP's question.
an uberturbine 20" wheel, with the rubber is a larger OD than say the 18" aero with tire.
