rb92gt
- Ryan
- Jun 29, 2024
- Cyberbeast
- #1
Cybertruck new USB Flash Drive Install and Formatting instructions:
Purpose - For a much larger capacity multipurpose USB drive, I used a Samsung SSD T7 2TB. It will hold a ton more Sentry and Dashcam footage than the stock USB flash drive that came with the truck, located in the back of the glovebox USB-A port.
Some particular things need to be done or it won’t function properly:
New drive must be formatted in exFat with four partitions:
Plug new USB drive into your personal computer, then type “Create” in search bar at bottom of Windows computer (if Mac there’s another way I’m not privy too but a quick google search should get you there), select “Create and Format Hard Drive Partitions,” right click the USB drive and choose “Delete Volume.” It will then read Unallocated. Then create four partitions (case sensitive) -TeslaCam, LightShow, Boombox, and Audio. In the LightShow partition place a folder named Lightshow. In the Boombox partition place a folder named Boombox. In the Audio partition you can place mp3 music files, wav files, etc. These can be played in the truck's media player.
For instructions on adding LightShow files, this is a good source, and also confirms the above:
Using one USB drive for Custom Light Shows, Boombox, Lock Sounds and Tesla Cam - Your Personal Ninja (ustech.ninja)
If you want a custom lock sound for the external speaker, find a file that is in .wav format, some good ones here- Popular Tesla Custom Lock Sounds & Chimes - Video Games, Cartoons, TV Shows, Movies and Retro / 90's , (notateslaapp.com) , change its name to LockChime and place the file in the Audio partition (not within a subfolder). Then BEFORE plugging USB into truck, open Toybox, change source of LockChime to anything OTHER than USB. Then plug in USB Drive in truck (Must plug into USB-A drive in back of glovebox) and select USB as LockChime source on screen.
Good to go! Enjoy. Took me three hours to figure the above out, hopefully saves you some time.
