What Motor(s) will the Cybertruck use?
TruckElectric
Bryan
Dodge Ram diesel
Most truck users want to know what is "under the hood". In ICE trucks they want to know the horsepower and the torque.
In EV's it's "what kind of motor and how much torque does it produce".
Since Tesla does not publish power ratings on their motors we have to rely on dynamometers. There are some dyno tests on YT with the Model S.
The Tesla Semi will use the Model 3 motor, the AC Reluctance Motor. I've read where in the dual motor Model 3 the Induction motor is used in the front and the Reluctance motor is used in the rear.
So I'm thinking the Cybertruck will use the AC Reluctance Motor.
The Reluctance Motor used in the Model 3 is an PMSRM-Permanent Magnet Sychronous Reluctance Motor.
There was some speculation that the PMSRM is a "Switched" instead of Synchronous Motor. This was proven wrong after a teardown of the motor revealed imbedded magnets in the rotor.
Tesla Cybertruck What Motor(s) will the Cybertruck use? ACTUAL-Rotor-close-up-with-laminates-3
BMW uses a similar motor in the i3 they call a hybrid synchronous electric motor.
Tesla Cybertruck What Motor(s) will the Cybertruck use? Image 7-20-20 at 12.15 PM
I doubt Tesla will release what kind of motor(s) will be used in the Cybertruck so we won't know until there is a teardown of the motor once someone like Sandy Munro does one.
I have no doubt the Cybertruck will live up to hype and will have TONS of torque!?
I really have no idea what it is other than it has magnets and so is clearly a synchronous machine. Let's call it a PMASRM (Permanent Magnet Assisted Synchronous Reluctance Machine). Only problem I have with that is that I can't see any salience in the stator (which does not mean it is not there).
TruckElectric
TruckElectric
Bryan
Dodge Ram diesel
Permanent Magnet Assisted Synchronous Reluctance Motor, Permanent Magnet Synchronous Reluctance Motor or simply IPM are all acceptable. It's just how descriptive you want to be.
Dids
Les
Massachusetts
04 Tacoma, 23 Cybertruck
Self
Since Model 3 uses both an induction and reluctance it's a good guess that the dual motor CT will be similar set up. With the single motor CT being an induction? Does that mean the 3 motor uses 2 reluctance motors? Or do we think the 3 motor is plaid with some other setup?
TruckElectric
TruckElectric
Bryan
Dodge Ram diesel
Good questions. My guess? Single motor CT will use PMSRM. Dual Motor like you said Induction and Reluctance. 3 motors will use Induction in front and 2 PMSRM in rear.
My best guess!! ?
I have neither a CT nor a dyno to put it on. Nonetheless we can WAG some numbers from the specs if we assume a weight. Guessing that that will be about 3000 kg the 0-60 time of 2.9 seconds gives us 27.74 kN thrust just to get the mass up to 60 mph assuming that the acceleration is uniform in those 2.9 seconds. If we assume 50 cm wheels (for easy math) the torque is 55.48 kN-m. Further assuming that peak power is delivered at 60 mph its easy to calculate that at 744.8 kW (just shy of 1000 hp and 1935 A from a 385 V battery). Splitting between 3 motors gives us around 333 hp per motor and about 18 kN-m from each at the wheels. Assuming motor shaft speed of about 8000 rpm at 60 mpH we'd have about 1 kN-m per motor.
I know that's a raft of assumptions but it does give us ball park numbers.
TruckElectric
TruckElectric
Bryan
Dodge Ram diesel
I still like to see the numbers a dynamometer test gives. The CT will best the production diesels.
Ryan95738
Ryan
Skagit Valley
CyberTruck
CNA
I think the 3 motor will be plaid and with be like "alien technology" to quote Musk.
ricinro
Rich
Mesa Az
mech design engineer-ret.
50cm wheels? the wheels shown are closer to 88.9cm in diameter.
Scale by the ratio. But 17" radius seems kind of small to me, especially for a hefty truck.
TruckElectric
TruckElectric
Bryan
Dodge Ram diesel
Here is a Model S P100D dyno results
Source: Tesla Model S Dyno
Do you think the Cybertruck Tri Motor will beat that? Yeah, I think so! ?
I forgot to mention in the video they said there was some slippage during the testing and could have made more HP and Torque without the slippage. The Tesla Model S P100D just couldn't be restrained!
Kinda Like trying to restrain Frankenstein........
Tesla Cybertruck What Motor(s) will the Cybertruck use? 320a9663bc29597e75f2391456a84a4d
Cybertruck will be a monster!
android04
Crete, NE
My best guess!! ?
My guess is similar but switched on Dual and Tri. I believe the layout will be more like that of the Raven Model S and X where the front motor is PMSRM and the rear motor is Induction. The Tri will have 2 Induction motors in the rear, or possibly one Induction and one PMSRM in the rear.
