Will magnets stick to the cybertruck?
robk444
Robert
east northport
Does anyone know if the stainless steel the cybertruck will use will work with magnets?
I'm planning on living out of my cybertruck a decent amount (While traveling cross country) and it would be great to have an awning that I can just have 1 side magnetically attached to the vault rails or the roof edges.
www.timeanddate.com
Tesla is using a unique formulation of stainless steel, but the DeLorean skin is not at all magnetic.
Since the CT body is mostly flat, you could always use suction cups.
https://www.walmart.com/ip/Follure-...59742?wmlspartner=wlpa&selectedSellerId=18988
BillyGee
Bill
Northern California
Technician
If it's decent stainless, no.
Klaxon
CT
The stainless steels of 400 series are magnetic, but a bit less magnetic than regular black steel.
The stainless steel 300 series is not magnetic or slightly magnetic when hardened.
The reason for that is that 400 series have about 13-20% of chromium and very little of nickel. The 300 series have the same amount of chromium and 7-13% of nickel (plus molybdenum, titanium and other components in quantities less than 1-2%).
So nickel makes difference
robk444
Robert
east northport
Thanks for the input. I guess if it's not magnetic then suction cups should work ok.
John K
Volt, CT reserve day 2
Have you considered latching the awning on to the L-track. Once production begins, many suggestions will abound if you have not found the ideal solution for your use.
CyberJay
J
NJ
Cybertruck AWD (two), Model Y
Oncology Biotech Exec | GOD BLESS THE USA
Just an update - YES the formulation used on the CT seems to be magnetic - here's a video for the Frunk - which I'm certain is probably the same as the rest of the vehicle...
stevegshi
Steve
Virginia
RAM1500, Model 3
Contractor, Electrical Engr, Master Electrician
yes, magnets work on cybertrucks. TSport did the test in one of their early videos when they had two cybertrucks in the shop for customization work.
mark555055c
Buffalo, NY
It is magnetic.
Incorrect
ideaXfactory
IdeaX
MO
Many trucks, and a Porsche
It would be interesting to try a normal magnet vs. a Neodymium (rare earth) magnet on it vs. both on mild steel.
CybertruckRN1127
Palos Verdes Estates
Model S, Model 3, Model X
Someone above already posted it's magnetic. You can also see wrap videos where the installer use magnets to hold the vinyl in place while they line them up.
