- Aug 17, 2022
- Austin, TX
- F150L
- Fun-employed
- #1
A thought experiment to set this up:
Take the CT "endoskeleton" as we know it based on recent photos. Then consider two different vehicles built around it.
Both have identical suspension robustness.
In the first vehicle, hang upon it conventional sheet metal like the Model Y, fastened to the frame/casting in the same manner as a Model Y. Call this first vehicle the 'Body In White' version of the CT.
In the second vehicle, hang upon it instead 3MM SS, and rather than fastening it conventionally, use a multitude of fasteners, adhesives, brackets, etc., to effectively 'weld' the SS to the internal castings/frame, including across the joints of the casting/frame seams. Call this second vehicle the 'Exoskelton' version of the CT.
Now consider the operational/functional delta between the Body in White CT and the Exoskelton CT.
Cory at Monro appears to be indirectly maintaining that those two vehicles will have identical payload/towing capacities, and identical behaviors when put under identical tortional stress. Doesn't that seem a bit precarious?
From my armchair, I suggest it's possible that Tesla both:
- manages to make the 'Exoskeleton' CT materially outperform the 'Body in White' CT, and
- given that material difference in capability, all owing to the outer skin construction, can justifiably claim that the performance of this CT is due to its "exoskeleton"
