3 Ways to Install Your Wolfbox Dash Cam – Which One Works Best for You?
Wolfbox
Florent
If you’re new to Wolfbox or just looking for the best way to install your dash cam, we’ve got you covered! Here are the three most popular methods to get your Wolfbox dash cam up and running. Each has its pros and cons, so you can choose the one that fits your needs best.
Rubber Strap Installation
This is the simplest and quickest way to set up your dash cam. Using the rubber straps included in your package, you can secure the dash cam directly onto your car’s original rearview mirror. It’s straightforward and requires no extra tools, making it perfect for beginners. However, some users find this method a bit bulky, as the dash cam sits on top of the original mirror, adding some extra thickness.
OEM Bracket Installation
For those who prefer a sleeker and more integrated look, the OEM bracket is the way to go. This option requires purchasing the Wolfbox OEM bracket separately. You’ll need to remove your car’s original rearview mirror and its supporting bracket, then replace it with the Wolfbox bracket. While it’s slightly more time-consuming to set up, the end result is worth the effort. The dash cam will look like it was part of your car’s original design!
Video tutorial:
Center Console Base Bracket Installation
This method is different from the traditional dash cam placement. Instead of attaching the dash cam to the upper windshield area, you can mount it on your car’s dashboard using a dedicated stand. This gives you more flexibility in positioning and keeps the windshield clear, but it may take some time to adjust the angle for the best recording view. If you want a distinctive setup or have a unique windshield design, this could be the option for you.
Video tutorial:
We’d love to hear from you!
Have you tried any of these installation methods? Share your experience, tips, and tricks in the comments to help new users find the best setup for their Wolfbox dash cam. Your advice can make all the difference!
BlueLightning
Thomas
Oklahoma
Retired USA, Army
Dashcam, maybe should be called Center mirror Cam.
Ok, and why does the Cybertruck need this camera gimmick?
Already built in…
cyberjeff25
jeffrey
temecula california
cyberbeast
registerd investment advisor
Why do you need to add a rearview mirror for God’s sake? You have a rearview camera already you can expand to cover the entire huge screen. Just because your a creature of habit and need a screen that looks like an old fashioned rear view mirror. I took that silly mirror down the first day and have never missed it ever. Adding this fake rearview mirror is silly.
misdemeanor
Kentuck-lette
www.TeslaKY.com
‘25 CT, ‘22 YLR, ‘22 3LR
All. The. Things.
The digital rearview has advantages over the existing rearview camera:
  1. Probably the top reason is that it's less susceptible to water since most people install it at top of the tonneau. There are covers you can purchase or print
  2. Helpful if you've got the tailgate down while hauling something. Otherwise you'd be looking at the ground
cyberjeff25
jeffrey
temecula california
cyberbeast
How often do I drive around with my tailgate down- never. So you start mounting things in the cabin/ back uncovering ? A solution for a problem that does not exist. Next installing a dash cam ???
MICyber
Michigan
2024 Cybertruck AWD Foundation
I've had my G900pro for over a year and still no mount for the Cybertruck. I've contacted Wolfbox directly and posted in the forums and nothing. The CT ball is too small to fit the mounting plate. I have a workaround with 3D-printed filler pieces but it is just a bandaid. Why promote your products here when you have not supported the CT?
misdemeanor
Kentuck-lette
www.TeslaKY.com
All. The. Things.
Not often
