mmmmmb
Rapid City, SD
Signature Model S, Performance Model 3 2018
All,
I would like to report to you that I drove over 9,000 miles recently with the FSD 12.5.5 (and its variants) in my new CyberBeast. Here are some details:
10/09 : Started in Palo Alto and drove to Los Angeles (CyberCab event) : 400 miles.
10/11: From Los Angeles to Phoenix : 400 miles
10/14: Drove to Satellite Beach Florida: 2300 miles
10/22: Drove to Richmond, VA: 800 miles
10/26: Drove back Phoenix, AZ: 2300 miles
10/28: Drove to Las Vegas, NV: 300 miles
10/30: Drove to UC Santa Barbara: 400 miles
11/03: Drove back to Palo Alto: 300 miles
11/05: Drove to Portland, OR : 700 miles
11/09: Drove back Palo Alto, CA: 700 miles
Miscellaneous driving at each of the places: 500 miles (may be even more)
Total miles: 9,100 miles.
Tesla Cybertruck FSD Review - Over 9,000 miles in Cybertruck CyberBeast 1732476302155-dm
This entire time, I was all alone in the Beast along with my little pug puppy! I used the FSD for almost all the time. It is amazing, of course. It makes driving so much easier, I was able to drive through the night (without checking into a hotel) twice, once on my way to Florida, and once on my way back to Phoenix. Just to be sure, most of the drive is on the first release of FSD for CyberTruck, and a little on FSD 12.5.5.2.
I am not sure if there are any critical interventions at all during this entire experience. While this is obviously amazing, I also knew its limitations, so I would act accordingly before it would need an intervention. Here are some of those things I have done:
  • I would give a signal to make it change lanes so that it doesn't wait until the last minute to make lane change (for example. to exit the freeway).
  • I took over completely as soon as the car drove into a super-charger parking lot. It seems to make a lot of mistakes once it is in the parking lot.
  • I started off using Auto Max Speed, but I ran into a problem. In one stretch, I got the warning saying that I needed to stay below 70mph (to make it to the next charger), but FSD is happy driving over 70MPH. At the time, I didn't realize I could simply switch over to User Max Speed, so I ended up turning off FSD. After that stretch of about 100 miles, I drove the rest of the time with User Max Speed. In this process, I learned that even if I am using User Max Speed (mine is Speed Limit + 10%), it seems like the truck would drive at lower speeds anyway. It seems Auto Max is still in play even though User Max Speed is displayed.
  • Whenever it was driving too slow, I would press the accelerator pedal to make it go faster. It seems to understand my need, and it stays at a faster speed even after I stopped pushing the accelerator pedal.
  • It does go into the wrong lanes (to the left of the yellow lines) a few times, especially when there are no other cars around. In those cases, I would take over – so, in theory, it is not a critical intervention.
Speed
Since I drove many 1000’s of miles in a very short period, I got to notice lots of behaviors and was able to think about possible reasons behind them. Here are some observations that still baffle my mind and I would like to discuss them here to see your reactions. Would love to hear from your points of view to see what I am missing.
  • Others have documented it, but the car seems to be too slow most of the time. But, I can’t figure out the reason. The car almost always wants to go slower independent of what road conditions are, the nearby traffic, day vs night, good weather vs bad weather, the actual speed limit, the max speed limit, and the Auto Max whether it is explicitly set or not.
    Tesla Cybertruck FSD Review - Over 9,000 miles in Cybertruck CyberBeast 1732476613848-jc
    Here are some examples:
  • Actual speed limit is 65, Max is set to 75, and the car drives at 62 for extended periods of time. By changing 75 up to 80 didn’t make any difference, but changing it below 65 would make a difference. Tapping the gas pedal will bringing it up to 75 and wants to remain there, it seems.
    Tesla Cybertruck FSD Review - Over 9,000 miles in Cybertruck CyberBeast 1732476540872-mf
  • My automatic offset is set to 10% more. But, many times, the max speed is not adjusted, even though it sometimes adjusts it. For example, I am driving with 70 speed limit, Max is set to 77, and the car is driving at 75. Speed limit changes to 55 and the screen reflects it. However, at times, the car speed remains at 75 and Max is still set to 77. At other times, the speed limit and the max change to 55 and 60, respectively, and the car slows down right away. This inconsistent behavior bothered me.
    Tesla Cybertruck FSD Review - Over 9,000 miles in Cybertruck CyberBeast 1732476472009-jy
  • There are other times, for example, when I am taking the exit, the speed limit numbers seem to be confusing. I have seen on the screen the speed limit is 70, but the max speed changes to 40 or 30 as I am exiting. While this may make sense, I don’t remember the older software did that. The car simply slowed down without adjusting the numbers on the screen. That may be better for UI.
Lane Changing
CyberTruck doesn’t have driver profiles such as chill, standard, and hurry. Not sure how it decides to change lanes when the traffic is slow. Here are some examples:
  • Some of the times, especially, when it is nearing an exit, the car seems to want to change to a left lane from the right lane even within 0.5 miles from the exit.
  • Other times, it would drive very slowly behind a truck for extended period of time even when the next lane is empty or moving a lot faster.
  • When I give a signal manually, it takes a long time for it to initiate the lane change it seems.
  • Sometimes it takes more than 10 seconds for it to complete the change even if there are no other cars in the next lane.
  • Sometimes, the blinker is on, but FSD seems to ignore it.
In general, I expect FSD to know where all the surrounding cars are at all times, and when I initiate the lane change, I would expect the car to take it seriously – not think about it for a while. Customer initiated commands need to be acknowledged and implemented in a hurry, not just a suggestion – of course safety comes first. Imagine when you press the accelerator pedal, the truck thinks about 10 seconds before accelerating – not a good thing!
Charging
When I am doing charging at the super charger, it tells me that it is ready to go when it has enough charge to reach the next destination. It seems the algorithm wants me to get there with a charge of 10-20% left. However, there seems to be some confusion, at least in my head. Here are some examples:
  • When I disconnect from the super charger, it will show me that the charge expected at the end of the next stretch would be, say, 15%. As soon as I start driving, within a mile or two, it would jump up to 25%. Not sure what changed in that minute or so driving.
  • I also noticed that if I forced it navigate again, the expected charge at the destination will change. In the above example, after it jumps to 25%, if I stop the navigation and restart the navigation, it will drop back down to 15%. Weird!
  • In one case, I only had one charger (explicitly set) which is reachable with the current charge, and the final destination that is more than a 1000 miles away after the charger. The navigation system shows that charger is reachable with the charge level left at 15%, but the charge at the final destination is set to 5%, even though it is obvious that there is no way the car can get there without any further charging.
    Tesla Cybertruck FSD Review - Over 9,000 miles in Cybertruck CyberBeast 1732476667742-u7
Here are a couple of questions based on these examples:
  • Which speeds does it use to calculate the charge levels? Does it use the speed limits based on the navigation system or does it use the offset (+10%) to make that calculation? This is pretty important, it seems, but not sure how it is used.
  • Why does the calculation change suddenly from at the supercharger to when I am driving.
Other Issues
One of my mudguards broke off, and the Tesla service decided to charge me for the replacement. Didn’t seem right, but, of course, Tesla Service seems to think that they don’t even need to talk to the customer.
Still no communication from Tesla sales when I may be getting the hub caps, the light bar, and the super-charger miles in lieu of power-share.
FSD would occasionally put up big-red-hot-steering on the screen with a lot of beeping and ask me to take over immediately. This method was used to tell me that I was getting a strike-out in the past versions of FSD – so, I would almost panic. However, with this new software, it tells me that FSD quit because of System Error. This happened more than 10 times during this long drive, but not sure why. When the weather is bad (raining or direct sunlight), it seems to happen a lot more. But, it also happened when everything seems normal.
Conclusion
After driving 25,000 plus miles since the end of May when I picked up the CyberTruck, it handily surpassed my Signature Model S from 2012, and my Model 3 Performance from 2018 in terms of driving pleasure. (Of course, I drove X and Y at various times when I picked up the loaners.) The truck is smooth and comfortable.
FSD is amazing. Even with all the observations listed here, I would say the number of significant interventions over 9,000 miles are less than a handful (not counting giving signals, tapping on the accelerator pedals, and parking lots). I have to say I am actually less comfortable driving without FSD turned on, vs having it on.
Not having the steering nag is amazing! With the old software when the steering nag was the main safety, I used to get a strike every 500 miles easily. With the vision based attention monitoring, I only had one strike out in 9,000 miles. In that case, I am not sure why, however. Wish it told me how I screwed up!
Sorry for the long post. Would love to hear your feedback from you all!
Best,
Mohan
Tesla Cybertruck FSD Review - Over 9,000 miles in Cybertruck CyberBeast 1732476938641-kw
TorqMonstr
Scott
Beast, M3, MY
Auto Mechanic
I just completed a 900mi trip from LA to the Bay Area and FSD definitely made the drive extremely nice. One issue I had where the vehicle was lining up to exit the freeway and the off-ramp was backup up leaving my vehicle hanging its ass off into the lane. I intervened as I was observing the traffic from my side view mirror and pulled the vehicle out of the way. I hit the record button shortly after that and this is what was recorded:
Btw, the resolution of the video is quite good!
Garee
Gary
St Cloud, Florida
I am having some charging issues on my generation, three home charger. When I plug it in, I get a red cyber truck lite and not charging. I take it to a supercharger and it works fine. I changed wall chargers and still does the same thing. I used a friends wall charger in it does the same thing. Super charger works fine. Does anyone else have this problem? I will be taking it in to get it. Serviced in another week or so, but in the meantime, I have to use the superchargers.
guy driving the box truck probably had his face shoved in his phone. what a jerk
Others have had this same issue with the inverter.
shopaholic
Gee
East Bay
Thanks for a super detailed FSd rundown. Agree with all the points you made regarding the “weird “ behavior, hope they will fix with V13, to be released soon. Curious as to your consumption numbers.
sirozha
Atlanta
Tesla Model Y
I’m glad you enjoyed FSD. Your pug, though, looks scared.
no%X#XMVk65v#cq
J
CT FS AWD
The speed thing needs to be sussed out.
My biggest issue is it thinks ALL COUNTRY roads around my neck of the woods are 25MPH zones. I can't understand why it doesn't know the speed limit when waze/google/other nav systems do.
jimbobb23
Cybertruck....
The current FSD on the Model Y (12.5.6.3) has Hurry mode which fixes most the freeway speed issues. Not perfect yet but way way better. It aggressively tries to get to the speed it should. On normal roads still not so much. Very sluggish with speed. They need a Drive it Like you Stole It mode and it will probably be perfect.
RonGonRetired
Ron
WY
2013 Model S, 2005 Chevy SSR, 2016 Chevy 3500HD High Country
Good report, I recently did a roundtrip Vegas - Santa Barbara and used FSD most of the trip. I agree with most of the issues you mentioned, some of my own observations is after a couple weeks using FSD it seems to have learned I prefer HOA lanes if available, but it has a tendency to exit then reenter randomly. when it exits it is at a spot where the HOA lane allows that but don't know why it leaves then re-enters. Noticed on Lon drive on 2 lane highway it will go as fast as I want (like 75 in a 65) but has a tendency to keep gradually decreasing speed 1-2 mph until it drops off to @ 5 mph over. If you go 91 MPH it turns itself off and refuses to work for the rest of the trip ( until I turned the truck off then back on) Really didn't realize I was going that fast until it shut off (I-15 between Barstow and Vegas 80+ is pretty much normal traffic flow on a Friday). Wish the ability to scroll the right wheel down to gradually decrease speed like the adaptive cruise used to do. Hate having to turn FSD off to decrease speed, I understand update .3 is going to address lane changes for exits at a more reasonable distance I too have had it change to a left lane instead of exit or right lane, this caused me a 5 mile detour recently here in Vegas because it was too late to take control and exit safely. Other than minor issues Loving FSD, my wife doesn't like the way it hugs the left side of the lane,
Tesla Cybertruck FSD Review - Over 9,000 miles in Cybertruck CyberBeast kpontrkn
mmmmmb
Rapid City, SD
My home has the V1 Home charger from Signature Model S 2012 days. It charges my 2018 Model 3 and the original Model S fine, but CyberTruck immediately turns red. No one could answer why that was, but finally some service guy said CyberTruck uses some new standard that is not compatible with the original (not sure when they changed it because 2018 Model 3 works fine). My CyberTruck seems to work fine at other home chargers (both at work and service places).
mmmmmb
Rapid City, SD
I didn't really record diligently the power consumption numbers as so many have already reported them. I remember seeing numbers around 420 mile/Wh.
mmmmmb
Rapid City, SD
Haha - my pug got used to running into the fast food places to get some food everytime we stopped. So, that look is not about being scared. it is about "when are you going to feed me?" look!
mmmmmb
Rapid City, SD
Yes, getting in and out of HOV lane has been a problem for me as well. And, hugging the left side of the lane is also something I experienced. Sometimes, it just drives on the reflectors and even on the noisy safety thing they have beyond the yellow line (not sure what it is called). I was wondering FSD can make use of vibration/sound sensor for it to know it is driving on the median?
Macgreiner
Mac
Maryland
Global Operations
