T Sportline
Brian
Los Angeles & Atlanta
tsportline.com
Upgrading Tesla Cybertrucks!
Hey Cyber Nation -
The new lightweight 2-piece rotors have launched! We've got them in stock and they look ??
Anyone want to come to Atlanta, we'll offer a special deal - and free install for the first local job ??
https://tsportline.com/collections/...erformance-slotted-cross-drilled-brake-rotors
Specifications:
  • Directional (curved vanes / slots) for maximum efficiency
  • Extends brake component longvevity through improved thermal management
  • Aluminum rotor hat improves heat dissipation rate and capacitance
  • DIY-friendly bolt-on installation (no brake fluid / bleeding required)
  • Compatible with factory brake pads (re-use existing pads)
    • Replacement pads are optional - recommended for optimal performance
  • Reduces rotating and unsprung mass by 12.2lbs (14.4% of stock wt)
  • Front Rotors:
    • 350mm x 32mm (same as stock)
    • 21.48lb vs 24.17lb stock weight (per side)
  • Rear Rotors:
    • 356mm x 32mm (same as stock)
    • 14.77lb vs 18.17lb stock weight (per side)
Tesla Cybertruck New Lightweight 2-Piece Rotors for Cybertruck - T Sportline x RacingBrake 04_CT Front Brake Rotors - W
Tesla Cybertruck New Lightweight 2-Piece Rotors for Cybertruck - T Sportline x RacingBrake 02_CT Front Brake Rotors - W
Tesla Cybertruck New Lightweight 2-Piece Rotors for Cybertruck - T Sportline x RacingBrake 02_CT Rear Brake Rotors - Web
CarMan ElecTruck
Other Earth
LeftFoot RightFoot
I admire that you don’t use sneaky/tricky thread titles to get people to come visit the thread..
Clearly a post about a companies new product.
And this product looks very appealing in many regards. Bravo!
T Sportline
T Sportline
Brian
tsportline.com
Always good to see new stuff from T Sportline! Have any numbers for us comparing stopping distance with these vs OEM rotors?
yes, it's frigid in Atlanta at the moment, but as soon as we get some decent weather we'll video a full test and post. coming soon...
dalton108
Dalton
Lawyer
? agree!
These sales posts intended to blend in as “organic” are infuriating and 100% of the time cause me to have a lower opinion of the company doing it.
Firstly, they all are transparent and bad which makes me think that the company in question is incompetent, in addition to being duplicitous! Which makes me not want to purchase product from them.
Secondly, I find it insulting to my intellect to even try it!
It’s a bad look that leaves a bad taste, and I don’t believe that admin should allow it!
Art138
Art
Weston,Florida
MYP,Ford GT & FS CYBERBEAST
I am interested but want to see if there is an improvement in the 0-60mph run (before and after). Maybe when they conduct the stopping distance test,this can be added too.
Came here to say this. The forum admins need to start cracking down on the super lame click-bait subjects from some of the other vendors.
T Sportline
T Sportline
Brian
tsportline.com
ya, no sneaking here - it's a new product alert ? - thanks for looking!
The Duke
Fremont, CA
Model S, CyberTruck
Engineer (retired)
Good matchup. I have RacingBrake on my P100D, stock size, upgraded pads and racing fluid. No fade on the track (remember the P100D is only good for a couple of hot laps). Over 100K miles and they show some wear, but work fine still. I did have to replace the parking brake pads, which is strange. RacingBrake makes good stuff.
Cyber_Punk_SFL
Florida, USA
2024 Tesla Cybertruck, 2024 Tesla Model 3
Do you recommend upgraded pads to go with these, or are the upgraded rotors themselves likely to improve braking?
The Duke
Fremont, CA
Model S, CyberTruck
Engineer (retired)
Will you be adding stainless brake lines to a package for better pedal feel?
T Sportline
T Sportline
Brian
tsportline.com
T Sportline
T Sportline
Brian
tsportline.com
can go either way, but for peak performance - add the pads too.
