DMC-81
Dana
Transformers Camaro SS, C8 Corvette Z51, Dodge Magnum R/T, 1981 DeLorean
Geek. :geek:
Remember, they had to match the overlay to speed of the DeLorean! :)
Interestingly, the added weight of movie props on the back of the rear engined DeLorean necessitated a frame extension with casters right behind the rear wheels to alleviate much of the weight to allow the wheels to spin like that. Add the engine sound of a Porsche and you get movie magic. :geek:
Ludus
Michigan
Buick SUV
For the next exercise, put Doc and Marty inside the CyberTruck, with the Screen used in Time Machine mode.
Back to the Future is the perfect association for CyberTruck. BladeRunner is Arty, Mad Max post Apoc edgy but Marty McFly and Doc definitely buy a CyberTruck in the future to replace the Delorean.
This might also be a fun use of Deep Fakes to insert Doc and Marty Dialog mentioning Tesla and CyberTruck.
charliemagpie
Charlie
CybrBEAST
An oldie but a goodie
wtibbit
Wayne
DFW
I'm curious where you got the top speed of the tri-motor Cybertruck as 130 mph, assuming that's what maxes out means. Top speed is not listed yet for the Cybertruck on the Tesla site. 130 mph would be the lowest-rated top speed of any Tesla. My Model 3 Performance supposedly has a top speed of 162 mph. I personally have never pushed it beyond 150 or so, you know, around town in traffic and all.........
There is some discussion about tires in other threads that may explain the relatively low top speed specs. The bottom line concerns the manufacturers' speed ratings for the CT's installed tire size 285/60 R20 123/120H. AFAIK there are no tires currently available in the 285/60 R20 size with a speed rating greater than S (112 mph) or load index equal to or greater than 121. I assume the tires installed on the CTs we've seen, with an H speed rating and a 123 load rating, were made specifically for the CT. The H speed rating is 130 mph, the same as the highest specified CT top speed. It's possible that the CT's top speed specifications are capped by the performance specifications of available tires, or even, the best specifications that can be achieved - for a reasonable cost - by current tire technology.
When you gear a motor for torque, or load, you lose top speed.
I would expect that's the bigger issue than the tires.
