Mozart
- Dec 27, 2019
- Santa Rosa, CA
- 2015 P85D, 2017 Model 3 RWD
- #1
Can CT tow a 23' Airstream?
Does this answer your question? It's what we have.Tesla said:With the ability to pull near infinite mass and a towing capability of over 14,000 pounds,
A 29' has a 6000 gvwr (for 29D per dealer, apparently more per airstream) and unit base weight of 4761. The single motor can supposedly pull 7500+ pounds. Considering how much you can put inside an Airstream and the mileage from a single motor, I think a single motor is doable though not recommended.Can CT tow a 23' Airstream?
Tri motor canCan CT tow a 23' Airstream?
Well, if it's only three tons, then the single-motor could do it just fine.Tri motor can
Remember the battery range too. It’s possible to loose nearly half your range when towing. So I would strongly recommend 400 mile range at least.Tri motor can
