CTSoFL
South Florida
Cyber Nation -
Building on the success of our 50" single row light bar, we pleased to introduce our new 'double-row' light bar!
All the goodness from the single applies again here, just higher output and a bolder look --
The new 'double row' version is IN STOCK now (the bed mounting kit is pre-order though)
https://tsportline.com/products/tes...-light-bar-with-roof-top-quick-disconnect-kit
Light Bar Performance
  • Size: 50 inch light bar width
  • Lens Combo Beam Pattern: Center spot, outside flood
  • Body: Extruded aluminum with black powdercoating
  • LED: Osram 5W LED Chips (single or double row)
  • Voltage: 48 Volt DC - Cybertruck Spec (no voltage converter required!)
  • Wiring: Sealed Deutsch connectors
  • Nominal Power:
    • Single Row - 250W
    • Double Row - 400W
  • Lumens:
    • Single Row - Raw 23800LM, Effective 11885LM
    • Double Row - Raw 27400LM, Effective 14565LM
  • Output:
    • Single Row - 1 Lux at 598M
    • Double Row - 1 Lux at 621M
  • Color Temperature: 6500k
https://theonion.com/fuck-everything-were-doing-five-blades-1819584036/
dalton108
Dalton
Lawyer
Fantastic. This is going on my wishlist.
Does this have the same drive setting restrictions as the OEM lightbar that requires the off-road mode to turn on?
Ahem. The OEM does not require ORM to turn on. ?
codeater
2021 Model Y LR, 2024 Foundation Series Cybertruck
Can I trade in my single row?
T Sportline
T Sportline
Brian
Los Angeles & Atlanta
tsportline.com
Upgrading Tesla Cybertrucks!
Any night/trail shots or video as you nicely did when the OG single row lightbar launched? My only hesitation then was around light output and direction - seemed overly center focused and field overlap with high beams (which I don't think you toggled on/off) felt like it would be high thereby mitigating incremental utility.
I imagine the double-row would be aimed a bit higher to get more reach our front, is there more dispersion in the beam pattern as well?
I will get some night video/photos - it's been on the lift messing around testing other new products, so i havent had a chance to get out and shoot yet.
T Sportline
T Sportline
Brian
tsportline.com
T Sportline
T Sportline
Brian
tsportline.com
for those asking about our bed rail storage kit, here is the video!
