Pumbaa
Ok…let’s explain.. you take off the front left tire then next add spacer and try to tight it up with the correct torch pressure 151 however the whole brake, wheel hub, rotator disc will turn upon give the torched so I’m unable to thigh up the spacer so still loose at this time. So I afraid the spacer will go off on the road. Sorry, more clear? What should I do?No, but if your truck is still on a jack you should lower it.
Am I understanding the problem correctly?
Ideally also use a torque wrench to optimize the amount of force.
