halcyon
- Jan 19, 2024
- Newport Beach, CA
- Model X
- #1
I'm normally not one to review products, but finally got these bad boys installed and they look fantastic and very OEM as many others have mentioned and very reasonably priced (often less than $600 with various sales/discounts). Several other sites look to be selling the exact same product, but Tesstudio seems to be the best priced and they've had excellent customer service via Whatsapp. After seeing all of the other running boards out there, they really do not match the visual style of the car and these make the car look beefier and more aggressive.
My kids love them as it makes it much easier to get in the car (it is a bit high for them and myself even on entry mode). It is a bit awkward for myself to use as an adult, as after you step on it, you have to duck to get into the car, but it will be less wear and tear on seat rubbing getting in and out.
One thing to note is that the left and right mounts looked to originally have been two different types of SKUs, but are now just the same with holes available for each mounting side. It wasn't very clear which hole to use, but essentially you use the rear bolt so that it pushes the boards more forward. It is also more clear that only one hole will work on the mounts that are next to the jack points (see images). My understanding is that some of the other running boards may prevent the use of one or more of the jack points, so another bonus for this one.
I would argue that the washer they use should be a little larger, so hopefully they can fix this in future iterations.
Feel free to order using the link here:
Link
Link
