sanaoil
aj
vegas
MXP, Cyberbeast
I got te37xt m spec and 3d printed the hub centric rings 84.1 and 112 in abs plastic. However, I'm using Rays's center caps and it won't with the print. Do you happen to know the outer ring size for your custom hub rings? ?
Were you able to fit the centercaps? Also where did you buy the hub rings please? About to run te37xts too but I am getting mixed responses, but majority said no need to use hub centric rings. Thank you!!
sanaoil
aj
vegas
MXP, Cyberbeast
The Tumbler
AJ
Alamo, ca
2024 Cybertruck FD series Dual Motor AWD
Real Estate Broker
Dude. love it. This was the look and wheels I wanted. Best look on a CT Ive seen IMO. Given my towing and bed load needs I had to find a different wheel with a load rating closer to OEM. I believe these are only 2100lbs each correct?
