Jesseg9163
Jesse
New York
www.flipit3d.com
CyberTruck
I made this housing for that specific camera.
I received this product at no cost in exchange for my honest review below.
Opening the box I was initially quite impressed. Shipping was really fast and they included a lot of items, all individually packaged. It might be silly, but the quality of the packaging was higher-end so I could tell they cared. I opened each of the packages and soon realized that this was going to very much be a "figure it out" install and not a Cybertruck specific process. The kit and included materials were all generic meant for your typical 12V vehicle. The kit came with no installation instructions aside from connect power, connect camera. I didn't think I was going to be able to use it for 2 reasons - the OEM mount for the mirror is not compatible with our vehicles and the multiple power cables they sent were all for 12V vehicles. I contacted support and while responsive and very willing to help, I don't think they understood the Cybertruck nuance and how atypical this install was. Eventually, they pointed me to their OBD2 power cable, which was the simplest way to get power to the screen. They also sent this free of charge and that was the piece I needed to finish the install. The other issue was the screen mount. I ended up using the straps, but they fit loose since the OEM mirror is so small that the Wolfbox tends to bounce and shake a bit while driving. It is usable however.
Moving on, I used a couple of YouTube guides to install the power and camera cables. Power cable was pretty straightforward. The length was perfect and it was easy to run with not much guidance. The camera cable was bit trickier but also not too bad. The length of the cable I thought was going to be an issue (it's way too long), but I was able to wrap it under the side panels above the doors.
I removed the camera mount and used VHB to fix the camera directly on the panel above the tonneau cover where everyone else puts it. I put mine a bit lower on the panel so I could see in the truck bed, which led to about 5-6" of wire that are driving me nuts (see pics). I will figure out a way to hide it, I already have a few ideas.
The screen itself is massive, quite a bit bigger than I would have purchased on my own. Quality is great however. Clear picture (often better than the OEM one) day and night and a very responsive menu. I didn't bother to install the GPS since I really just wanted the rearview camera. I'll attach a few pictures below.
Aside from the install, my only complaints are 1) it doesn't turn off automatically since I think the OBD2 port gets power all the time, so I have to remember to turn it off if I'm going to be somewhere for a long time. 2) The FOV of the camera is exactly like the OEM one, which is way too wide to be able to judge the distance of a vehicle behind you. I may try to use a replacement camera if I can find one on Amazon that's closer to 80-90 degrees.
oKurwaCoZaPudlo
Denver, Colorado
My biggest issue with the mirror installed in that location is how much of your field of view it takes up. There is already a huge blind spot caused by the front pillars. I like to have my seat lifted high. My eye level is similar to that in your 5th picture. With the mirror installed, I'm losing a good 20% of what i see from the front right side of the windshield.
For this reason, i installed mine in a similar location to where another poster did a couple of weeks ago: right above the screen.
Jayse
Jayse
Las Vegas, NV
Cybertruck Foundation, Model 3
Designer
...For this reason, i installed mine in a similar location to where another poster did a couple of weeks ago: right above the screen.
Can you show it? or link? I was thinking the same. Or even installing above steering wheel. I mean it's a CT - we don't need it in the 'typical' location.
MICyber
Michigan
I’m still waiting for a complete solution that’s proven to work seamlessly. I have a S92 on the bench but won’t install it until they provide a power connection that leaves the right side speakers operational. Your always-on issue and mounting incompatibility kills this one for me. Thanks for posting.
I powered up mine with an ODB adapter and a 15' USB-C cord with a right-angle adapter. https://www.amazon.com/dp/B0FQV5T3BX
https://www.amazon.com/dp/B0BNMCMYNF
oKurwaCoZaPudlo
Denver, Colorado
CyberTrk
Cyberspace
サイバートラック
I have mine wired up with the USB-C from my center console. I got tired of waiting for a solution to the power issues they had. This is the cable I used, I got the 15V instead of the 12V. I can't remember what the reason was, but I something to do with power output. It's not hard to set up at all, just a pain to route the wires.
Can also use the USB-C from below the screen in the back, routing PITA but fixes the always on issue.
oKurwaCoZaPudlo
Denver, Colorado
Don't you have sun reflexion on your rearview digital mirror during the day? Something that I experienced so I moved my digital mirror where the OEM rearview mirror was located.
That's one of the downsides but even with glare I can ususally make out the cars in the mirror. Also if it is a situation where the sun is reflecting directly into my eyes, i can adjust the mirror angle a little.
Rippin1Gear
MJ
Seattle, WA
Foundation Cybertruck
plumber
I have yet to install my Wolfbox waiting on service to finish door replacements and front drive unit. I got the 3d printed larger ball so the OEM Tesla mirror mount works with the Wolfbox bracket.
Haven’t decided on what power route to go yet…
