- Roger
- May 13, 2024
- Poway, CA
- Cybertruck
- manufacturing
- #1
Happy Monday, guys and gals!
Wanted to introduce you to our new Adjustable Light-Duty Crossbar kit, just added to the site today. We created this kit for the majority of Cybertruck owners who are looking for a light-weight, light duty system thats capable of carrying; surfboards, snowboards, recovery boards, kayak, bikes, etc while staying on the 100lb weight limit.
We took our non-adjustable Standard Duty Kit, with Industry standard 1x2" bars, and then designed an adjustable stainless steel center plate that wraps around the top and bottom, then added our custom rubber extrusion to fill the opening side. This system mounts into any bar position without modification, and can easily be moved as your needs change.
Key Features:
Also works with all of the following accessories:
Key Features:
- Made from high-quality Aluminum extrusion and stainless steel with a matte black powder coating
- the crossbar mounts are not only robust but also resistant to rust and corrosion, ensuring longevity and reliable performance in any weather condition.
- With a load capacity of up to 100 lbs per pair, these crossbars are perfect for carrying light to moderate cargo, such as kayaks, bicycles, surfboards, snowboards, recovery boards, small rooftop boxes, or other outdoor gear.
- Designed to be versatile, we sell the crossbars individually, giving you the freedom to meet your specific needs.
- The user-friendly design includes all necessary hardware and instructions, allowing you to mount the crossbars quickly and easily.
- Easy installation with no drilling or modification required
- Made in the USA!
- You can add up to 2x MOLLE panels for customizable gear organization
- Utilize any Accessories with 1/4β³-20 t-nuts and hardware
- Tie Down tabs
- Heavy Duty angle brackets
