2024.14.11 Update
TeslaKen
TeslaKen
Ken
Overland Park
www.halocybertruck.com
Currently Occupied
The wiper stays down to vent the water and prevent it from running up the window. You can see it slide off. I have not figured out why it chooses to hold in the down sometimes and not during others, but for me it seems only when the rain is very light. If you leave it alone it will come back to home after a minute.
To further clarify, in my instance, no water, completely dry weather, day or night at some random time the wiper arm will suddenly come down and park for a bit, maybe 30 seconds, maybe a minute, maybe a couple minutes max, then it will go back up. Windshield is perfectly clean, doesn't seem to matter if heading into the sun or away from the sun and it has done it on a cloudy day, but again no rain or moisture, just a random wiping... it isn't a big deal to me, maybe it is on some sort of timer and after awhile it just decides to wipe for good measure I dunno, I assume at some point it will get fixed in a software update or I will get so used to it that i forget about it...
TeslaKen
TeslaKen
Ken
Overland Park
Currently Occupied
I have a model 3 as well. This doesn’t happen in that one.
I think what I will try is going into the 3, selecting all the items with a blue dot to clear them, then jump out and immediately into the CT and do the same and then see if they come back or not.
sgmorton
Sam
MS P100DL+. M3P, CT
Programmer
Yes I'm getting the same behavior. Random and dry... At first I thought it was detecting a dirty camera on the back but it seems to be really random.
sgmorton
Sam
MS P100DL+. M3P, CT
Programmer
Also for the record my Model S and my wife's Model 3 also do the random wipe when it's dry. I think it's just shitty software across the board.
JesseDGreat
Jesse
San Bernardino, CA
2024 CT AWD Foundation, 2022 Model S, 2023 Model 3
Finance Manager
I installed 2024.14.11 yesterday...but my CT is at the service center so cant try it out. but I did see "CHARGE OF SOLAR" on the top now!!! YEY
Nebucheri
Nebu
Plano, Texas
Cybertruck F S. Lexus RX450h+
This is exactly happened to me after the software update! No biggie anyway !
Pablito3
Paul
Sarasota / Miami Beach Florida
Escalade ESV, Cyberbeast
Real Estate: Investment/Development/Construction
Its seems like my phantom battery drain has been about halved with this update. I was getting consistently about 8.5% battery drain daily while just sitting with sentry off. In fact when I had sentry on, I had the same battery drain so that didn’t seem to impact the battery drain at all.
It appears my battery drain has gone down to about 4% per day from about 8.5% per day. I need a few days of non driving to confirm this for sure. The 8.5% drain is just wrong, how the truck is using about 10kwh per day just sitting is a serious issue. TBH 5kw daily is still alot but it’s a huge improvement from 10kwh.
Anyone else see a reduction of the phantom battery drain with this update?
TeslaKen
TeslaKen
Ken
Overland Park
Currently Occupied
I did not measure my battery drain previously but I have noticed that it is certainly higher than my model 3 performance which I can charge to 90% and unplug and a day later maybe it is down 1 mile of range. On the Cybertruck after 8 hours it is already down 2-3 miles of range while still plugged in. I was going to install the teslafi app on it and see if I could have teslafi force a deep sleep state and keep it there and see if that has an impact.
TexasRaider
JR
Denton
Cybertruck + MS
Civil
Yes. Over 40mph the wipers parks down. Any time you enable cruise it turns auto wiper back on. So that combination causes this behavior.
Ditto for my CT. It’s sadly part of how Tesla's auto wipers work since I’ve had a Tes in 2017. I’m thankful that my 2017MS has an option for normal wipers.
SteelMyHeart
I noticed today that my wipers were going nuts after I pushed the button for a one time morning dew cleaning and then I looked in the wiper menu and it was set on speed II, not auto. Check to make sure your wipers are actually on auto and don't have some random switch over. Mine were on auto prior to update so not sure what happened but now only occasional phantom wiper, like once per 40 to 50 miles.
TexasRaider
JR
Denton
Cybertruck + MS
Civil
My CT switches my OFF wipers to AUTO every few minutes, I’ve noticed. As though it won’t let me have the wipers NOT ever on manual/off.
agordon117
Ohio
cybertruck foundation awd
When you engage cruise control, auto wipers turn back on. That's what's causing it.
agordon117
Ohio
Mine happens without ACC engaged. (2014.14.11)
your wipers revert back to auto during a period where you never turned ACC on? Because if you turn it on, and then back off, and the wipers are back on auto, that's normal. If you know for sure you did not engage ACC between turning auto wipers off and finding them on again, that's not normal.
TexasRaider
JR
Denton
Cybertruck + MS
Civil
Confirmed. I’ll submit my issue with Tesla.
Thank you. ??
