Gaximus
- Jun 22, 2024
- Mead, CO
- CyberBeast, Model 3, Jeep Wrangler, Yamaha R6
- Occupation
- Software Developer
by drill holes i mean, modify as needed. Worry about replacement later. Use a Dremel and a cut-off disk, most likely.You can’t simply drill holes because most crossbars (including OEM) require installation of a mount inside the cavity created by the little appliqué door, with part of the crossbar end device going into the hole, so it isn’t simply a matter of accessing the studs welded inside the hole - the entire rectangular hole is necessary to complete the installation.
