T Sportline
Brian
Los Angeles & Atlanta
tsportline.com
Upgrading Tesla Cybertrucks!
Cyber Nation -
Building on the success of our 50" single row light bar, we pleased to introduce our new 'double-row' light bar!
All the goodness from the single applies again here, just higher output and a bolder look --
The new 'double row' version is IN STOCK now (the bed mounting kit is pre-order though)
https://tsportline.com/products/tes...-light-bar-with-roof-top-quick-disconnect-kit
Light Bar Performance
  • Size: 50 inch light bar width
  • Lens Combo Beam Pattern: Center spot, outside flood
  • Body: Extruded aluminum with black powdercoating
  • LED: Osram 5W LED Chips (single or double row)
  • Voltage: 48 Volt DC - Cybertruck Spec (no voltage converter required!)
  • Wiring: Sealed Deutsch connectors
  • Nominal Power:
    • Single Row - 250W
    • Double Row - 400W
  • Lumens:
    • Single Row - Raw 23800LM, Effective 11885LM
    • Double Row - Raw 27400LM, Effective 14565LM
  • Output:
    • Single Row - 1 Lux at 598M
    • Double Row - 1 Lux at 621M
  • Color Temperature: 6500k
T Sportline
T Sportline
Brian
tsportline.com
T Sportline
T Sportline
Brian
tsportline.com
Fantastic!
What's the difference in vertical height on the single vs double row? Just trying to guess around wind noise, drag, etc.
let me measure. FYI I have been driving on the double-row for 3 months, no noise.
T Sportline
T Sportline
Brian
tsportline.com
Jack27
Randy
None
I really like your minimal look brackets. Way better then other after market one I saw with the entire steel all the way across.
not to fond of the quik disconnect though. Pretty easy to steal and who really needs to take it off?
I’m def going to have to get this sooner then later
TexasRaider
JR
Denton
Cybertruck + MS
Civil
Is this bar compatible with your original single row mounting hardware?
T Sportline
T Sportline
Brian
tsportline.com
the quick disconnect is optional - we include bolts too, so you can bolt on traditional style
T Sportline
T Sportline
Brian
tsportline.com
No, the brackets are a little different due to the height. But we could do a trade-in if someone wanted to upgrade, pm me.
T Sportline
T Sportline
Brian
tsportline.com
Would love a permanent (non-disconnect) feature. I'd never ever take it off. And suspect most wouldnt.
It is included! comes with bolts for traditional mounting too!
carsly
Vin
Princeton, NJ
LR Defender, CT AWD
Any night/trail shots or video as you nicely did when the OG single row lightbar launched? My only hesitation then was around light output and direction - seemed overly center focused and field overlap with high beams (which I don't think you toggled on/off) felt like it would be high thereby mitigating incremental utility.
I imagine the double-row would be aimed a bit higher to get more reach our front, is there more dispersion in the beam pattern as well?
