Charge Scheduling Bug?
loki
localhost
Anyone else having an issue with their charge scheduling? I set it to start at 12:15AM to charge when energy is cheaper. I find it will charge at random times regardless, sometimes right away, sometimes 11:15PM etc.
Gigahorse
AWD
Check two things.
1. You don't have a charge limit % set that would prevent it from charging.
AKA if you have a charge limit of 80% set and the truck is at 81% it won't charge at the scheduled time
2. Check your time zone settings in your ap and truck. If it is off by 1,2,3 hours it may be time zone related.
Do you have just the start specified or do you have the end as well? Just do one. If it is a time of day rate that you are trying to schedule for, then use the start setting.
If it is to warm the vehicle up for departure the morning because you are in severe cold areas, then use the leave by setting.
Does your energy get cheap at midnight? It's commonly earlier in the evening.
loki
localhost
Yes only the start. My plan has energy cheapest midnight to 3pm. Most expensive in the evening.
